Results 1 to 12 of 12
Thread: Changing 1 window to 3 window trip computer. VY Series II
    VY commodore acclaim
    Power Driver 2.0 Champion!
    Mar 2005
    Default Changing 1 window to 3 window trip computer. VY Series II
    Has anyone got any feedback about changing a 1 window trip computer to a 3 window job.
    What were the dramas? Is it a straight swap on a series II? etc.
    Krusty
    Darren's Avatar
    Darren is offline Site Administrator
    HSV Clubsport R8 E2 M6
    Feb 2003
    I suspect the following thread might be useful.
    Upgrading dash cluster to series 2 s-pack - warning!
    Chuck 'cluster' in the search this forum and a couple of others come up as well.
    I have never done this personally but starting to read the VY forum a little more since it looks as though I'm heading in that direction.
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    Provided you get the correct part number for your build date is a matter of plugging it in and programming it with tech2
    Rob
    vy v6 acclaim
    Apr 2005
    you may have to look at upgrading the bcm to a higher series also, but don't quote me on this
    Fekason is offline Fekason
    MY11 VE Series II SV6 Manual
    Mar 2005
    Penrith NSW
    Default No need for BCM Change
    The BCM change is needed if you want to install things like climate control aircon. But the BCM does not have a role in the cluster of trip computer, so you won't need to change that item.
    As Dr Rob said, make sure that you get the correct part number for your build date, install and have a tech2 done.
    If you get the wrong part number, you can get things like fuel guages working back to front.
    I have recently upgraded a VS S2 Executive to a level 3 cluster (from a Calais), and will be doing the same to my VY S2 sometime soon. Can't stand computer errors, so need to be able to calibrate, which is not available on the single window clusters.
    Go for it.
    Mar 2005
    Thanks Fekason. The hardest part is finding one without it costing an arm and a leg.
    Mar 2005
    Penrith NSW
    Default Be Patient
    Hi,
    I have been quoted $435 by a Holden dealer for a new one.
    There were a few around last year, probably when ppl changed Berlina/Claias/Statesman to HSV types. They appear occasionally still, so I would keep a lookout.
    I am waiting patiently for a source that does the changes to provide one. Hopefully that will be for a good price. If it works out, I will let you know.
    Mar 2005
    Quote Originally Posted by Fekason
    Hi,
    Thanks Fekason.
    I would be really keen if you come across a supplier.
    Krusty
    Phantom SS Guest
    Default Changed mine no worries
    I changed mine over without any problems from a VY SS dash to a 3 window VY hsv dash, clicked it in tech2'd it not a single problem....
    doogiedahdah Guest
    Mar 2005
    Penrith NSW
    Default Change the Fuel Sender Unit.
    Yes, it can.
    You can change the fuel sender unit, at a fair cost.
    There have been claims that it can be corrected with the software, but I have not seen that validated yet.
    Best to ensure the correct cluster for the build date of your car.
    Marks-VY's Avatar
    Marks-VY is offline I love cars
    VT2 Berlina
    Apr 2005
    That's correct, the only way to correct the fuel gauge problem is to change the sender unit to make it compatible. I asked Holden for a quote and almost fell over........not cheap.
  1. 3 window trip computer
    By dusted in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-05-2008, 09:58 PM
  2. single trip window to triple window
    By m_nairn in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-07-2005, 08:10 PM
  3. 3 Window trip computer
    By nabed4t in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2005, 04:05 PM
  4. Resetting the trip computer (3-window) (again)
    By fxjack in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-04-2005, 09:06 AM
  5. Rear window seals are coming loose, window is rattling whilist driving.. how to fix??
    By t3zza in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-05-2004, 11:58 AM
