Results 1 to 9 of 9
Thread: SS headlights
    VY Executive
    Apr 2009
    Default SS headlights
    Tried to the ss taillight conversion but failing miserably here's a few pics if anyone has a suggestion cause i've given up
    VY S Sedan
    Sep 2007
    Quote Originally Posted by jds.88 View Post
    I can see what your problem is,you're attempting a taillight conversion on the headlights.You've got the wrong end of the car .
    VY Executive
    Apr 2009
    VY Executive 2003
    Sep 2007
    The glue need to be hotter, i worked on a little area at a time with a hairdryer.... firstly i went around the light heating it near the clips and levered them up so they are no longer catching the clear plastic front.
    Next i worked between the clips heating the glue, running a small screwdriver between the seal and pulling out the overflow glue.... you do this all the way around.
    Next Start the lever start on one corner of the light, heat it up real well and lever it with a screw driver, if the plastic of the headlight starts to bend or chip, find a stonger area to lever.
    Work Down the headlight from the first corner down to about the middle (on both sides of the light) It gets a little easier from here.
    I got a second person here.
    I heated the each side for a while (few mins each side) and then from where you separated it from the top you should be able to pry it with you hands by pulling it apart. Remember to keep the glue hot/warm.
    The glue usally is stringy so just break the strands as you go.
    THIS PROCESS IS REALLY SLOW... TOOK ABOUT 1hour 30mins each
    VY Executive
    Apr 2009
    hey thanks mate
    I heated it up a bit more and starting to get somewhere, 1 half hour sounds about write
    The back half is taking a beating bending everywhere
    Is this ok?
    VY Executive 2003
    Sep 2007
    Try lever it in several places in a small area, rather than 1 place. it stops the bending and chipping of the plastic. Overall its the inside that you will be looking at, so dont be 2 worried
    VY Executive
    Apr 2009
    ok but how does it go when putting the headlight back in with all the grey back bit chipped and pried
    im seriously considering canning it
    Johnsy's Avatar
    Johnsy is offline ★★★★★
    HSV R8 LS3
    Oct 2005
    C/Town
    Get your local smash repair bloke to do it for you... offer him a quick cashy or pay him in beer
    VY Executive
    Apr 2009
    canned. been a complete waste of time and effort not worth it
    rather spend my time working over time and get the real thing
    thanks for help
  1. Exec/Acclaim Headlights --> SS Headlights for $80 ...
    By nEb. in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-06-2011, 11:06 PM
  2. HID headlights
    By mkymus in forum General Discussion
    Last Post: 13-08-2008, 11:15 AM
  3. vh headlights
    By dysolve in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-03-2008, 05:03 PM
  4. VY Headlights
    By SimonH in forum VY Holden Commodore (2002 - 2004)
    Last Post: 17-01-2006, 07:21 PM
  5. Need new headlights
    By tonitrus in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-01-2006, 10:58 PM
