Results 1 to 9 of 9
Thread: Door problem
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Default Door problem
    hi people i think i have a problem with my drivers door...
    after i unlock the door i find the outside handle to be very hard to pull up - i almost feel like i'm about to break it. Then to top it off when i shut it for the first time after this i can't get the door to fully close, only half shut. It doesn't matter whether or not gently push or if i fly kick the bastard it still won't fully close first go!
    Then after i open the door to fully shut it the door handle acts fine, and then on shutting it now it shuts fine....
    i repeated this 20-30 times this arvo with the same result each time.
    What the hell is going on?
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    VY Executive
    Apr 2009
    Mine has had similar problems, one morning thought door was Fk'd, after work it was fine ,also happened to passenger(not sure if because of hill parking)
    Mine went away and hasnt happened for ages...
    Mar 2008
    would it have been raining about then too? its only started this week since all of this bad weather has shown up.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    probably just need to lube the mechanism in the door vn's were bad for it drying out and then the handles tearing off.
    VY Executive
    Apr 2009
    Mar 2008
    so how would i go about doing that mr delco?
    VY Executive
    Apr 2009
    в∞ѕтεכ √&
    Jul 2008
    NZ
    take the inner door skin off and go to town with you favorite lube of choice.crc will free it up straight away but will soon rub off TAC2 is a good spray on lube that doesnt vanish into thin air.just whatever you have reallyspray the shit out the mechanism and pul the handle up and down a heap of times and she will free up
    Mar 2008
    thanks for the info boss, if it keeps going i'll give it a go on the weekend.
  1. problem with door lock
    By azz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2009, 02:05 PM
  2. Door lock problem
    By Secki in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-06-2006, 11:59 AM
  3. Door Lock Problem
    By JTW008 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-05-2006, 08:21 PM
  4. VT Door Problem
    By sausage in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-05-2006, 03:13 PM
  5. Door lock problem.
    By nomad in forum Electrical Wiring / Questions
    Last Post: 19-01-2006, 10:10 AM
