Do the black inserts pull out on the handbrake and shifter?
Yes there are plastic lugs that stick out, just use a small screwdriver to release.
The Blue One
Thanks alot man, shifter was easy, but what about the handbrake? I couldn't pull out the button
Ok i got it figured
HANDBRAKE
Take off top first with small flathead
Pull out plastic around button(got help from flathead)
Take out button
Vice versa to put together
SHIFTER
Take out top button(i wiggled back and forth, came out easy)
Two small screws u got to take out
Take out the plastic and put in new one
Also if shifter wont go in ur gona have to file it down a bit
Yep tats it, taking the button out takes abit of time.
The Blue One
