+ Reply to Thread
Results 1 to 15 of 15
Thread: VY Driver's Seat
    VY '03 SS
    Apr 2008
    Default VY Driver's Seat
    Hey
    I've got a problem with the electric seat. I can't seem to get the seat to move up and down. I have been told that its a motor issue ?? Anybody know what the cost of replacement would cost?
    Junny's Avatar
    Junny is offline purrrrrr Junny Executive
    VUII Maloo + shitty painted vp
    Hangman Champion!
    Jan 2009
    Quote Originally Posted by highflya View Post
    Hey
    might be the fuse
    Hit the star under this post if it was any help to you =D
    VY '03 SS
    Apr 2008
    VY Storm Ute
    May 2009
    I have the exact same problem. I can tilt backwards and forwards but not raise or lower it.
    My mechanic told me to pull the seat out and check the wiring under it. It's been raining since then so havent had a chance.
    Junny's Avatar
    Hangman Champion!
    Jan 2009
    Quote Originally Posted by StormVY View Post
    mine only has lets say, a front up/down and a back up/down. isnt that tilting? or u mean tilting the backrest?
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum Calaber W427 Calaber W427 Calaber W427 Calaber W427 Calaber W427
    VY II BERLINA
    Nov 2007
    LOwer Hunter Region NSW
    Quote Originally Posted by Junny View Post
    JUnny
    You have what is called the 4 way power seat, the same as the Utes. The power backrest (8 way power seat), only comes in Calais and up.
    You can check your wiring without removing the seat, simply raise it to the highest setting you can achieve and look under from the front.
    There are two motors, each with two wires feeding them. The wiring runs straight back into the switch which is screwed to the inside of the side trim. One motor controls the front raise/lower adjustment, the other motor the rear adjustment.
    To test the wiring, remove a power plug from one motor at a time - they are a simple push on fitting. Use a test light while you operate the switch to see if the switch is working correctly for each motor.
    If you get power to your test light on both circuits, then one of the motors is stuffed and this test will tell you which one.
    Junny's Avatar
    Hangman Champion!
    Jan 2009
    he did say he cant get it up or down.
    Calaber's Avatar
    VY II BERLINA
    Nov 2007
    Yep, and I said to raise it to the highest level he can achieve. If neither motor works, then he's already at that level, but if one still works, then he still might be able to raise the seat for more working space. One motor controls front lift and lower, the second controls rear lift and lower. If both motors are out of action, then it's probably the switch or a wiring fault. You can still look under the seat to see if anything is obvious, even if you can't raise it. Unless it's set at the lowest setting both front and rear, there is room to work and you can still remove the wiring connectors from both motors and run the test I suggested.
    VY Storm Ute
    May 2009
    I have a manual knob to control the back and a automated switch for the seat.
    When I tilt the switch forward the front of the seat lowers and the back raises. Vice versa when I tilt the switch backwards.
    My problem is that I am 2m tall and the drivers seat is noticably higher than the passengers. The tilting doesnt do much to raise or lower the height of the seat. I have been in other cars that have a feature when if you push the switch straight down or up the seat goes down or up.
    Ill check what Calaber suggested when my brother gets back with the ute.
    Calaber's Avatar
    VY II BERLINA
    Nov 2007
    It sounds like you only have one motor working. If you're lucky, it might only be a loose connection on the other motor.
    TMM's Avatar
    TMM
    TMM is offline OEM+ TMM has disabled reputation
    VY V6
    Jun 2008
    VIC
    The seat has two motors. One raises/lowers the front of the seat and one raises/lowers the rear. There are two switches connected to the knob. Try just toggling each end instead of tilting the entire knob and you'll see what i mean .
    when i got my car one of the motors/assemblies was seized (presumably because the previous owner never moved it from their position) but i got it working again by holding the button and helping the seat move up. Hasn't missed a beat since . Also check for a loose connection - You can reach the motors from the rear.
    ucrvme's Avatar
    ucrvme is offline [UCRVME] ucrvme Executive
    2003 Holden VY Berlina
    Mar 2009
    Melbourne, Victoria
    This is a very common problem - when i took mine to holden he charged me $34 but that was my circumstance - but he said its a fault with every vy
    VY '03 SS
    Apr 2008
    VY Storm Ute
    May 2009
    Quote Originally Posted by TMM View Post
    Champion. I found it was the rear motor by individually checking each end of the switch. Got under the seat and checked the connections, they looked ok but after wriggling them around the rear motor kicked in and now my head doesnt touch the roof! Thanks mate.
  15. #15
    binghy is offline Matty 038 binghy Executive
    Vy Equipe Series 2
    May 2009
    adelaide
    i have a motor set up for sale e mail me mattb075@hotmail.com
+ Reply to Thread
  1. VXII Berlina driver's seat
    By madcapmagician in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-07-2011, 11:20 PM
  2. Loose wire underneath Driver's seat
    By BullittSV6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 18-06-2008, 06:37 PM
  3. VX Berlina Driver's seat moves
    By Jom in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-03-2008, 08:25 PM
  4. VK Driver's Seat
    By CommodoreChick in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-11-2004, 06:37 PM
  5. VK Driver's Seat... Updated
    Last Post: 15-11-2004, 08:58 PM
