Page 3 of 20 FirstFirst 123456713 ... LastLast
Results 51 to 75 of 481
Like Tree2Likes
Thread: Issues with VY'S
  1. #51
    Morgasshk is offline Morgasshk
    VY Exec 3.8L Sedan 9C1 Pack
    Aug 2005
    grrr.... I'm starting to get a serious tap in the front end on start...
    Oil is fine, other fluids are fine, not due for service for another 7000 klms...
    I do drive it hard but only about 5% f the time, rest of the time os grandpa driving in traffic...
  2. #52
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by familyguy
    My VYII Exec has an issue with the bootlid setting the alarm off when you use the key button to open it BEFORE unlocking any of the doors. Anyone else had this?
    Steering shudder (known issue)
    Glove box sag (known issue)
    Steering noisy to turn sometimes (tie rod pin issue)
    Mine has the boot lid thing. Always wondered if that was a feature or a f&@(up.
    Reaper
  3. #53
    VYSSM6
    May 2005
    If your car is locked and someone crowbars your boot open would you like your alarm to go off ,I would but the car doesnt know the difference between your key and a crowbar so yes it will go off if you dont disarm the alarm first.
  4. #54
    familyguy's Avatar
    familyguy is offline Bog Standard
    VY Executive S2
    Jul 2005
    Northern Beaches, Sydney
    Quote Originally Posted by DazVYSS
    I'd have thought that the act of pressing the button on the key fob would signify that the vehicle knows that it was opened with the command button, not a foreign object (like a chinese crowbar).
    Cause sometimes I only want to put things in the boot and go somewhere else, not disarm the entire car.
  5. #55
    VYSSM6
    May 2005
    Sorry mate I see what you mean I just tryed my car and with all doors locked and just pushing boot release on key and open the boot the alarm did not go off.
  6. #56
    Aug 2005
  7. #57
    VYSSM6
    May 2005
    I am also experiencing a new issue since the edit and power upgrade to 320kw's when I nail the accelorator I keep seeing blue smoke out my mirrors and my rear tyres seem to be wearing badly is this a warranty fix (Help).
  8. #58
    Aug 2005
  9. #59
    Darren's Avatar
    Darren is offline Site Administrator
    HSV Clubsport R8 E2 M6
    Feb 2003
    Not exactly following the trend of the thread but back on the first page I mentioned I had a ticking sound which disappeared after the car warmed up.
    It turned out to be the S/C belt, they have replaced it with a 'revised' belt so they said and well it's been as good as gold since.
  10. #60
    VY2 SS
    May 2005
    Auckland NZ
    Quote Originally Posted by Davo72
    Thanks for thew info on the rear brake noise. What was the mod that they did
    Not sure Davo72 - but wheels run smooth on hubs with no noise (low speeds)at all now and has been good for last 20,000km. I'll ask my dealer and put the answer on this thread for you.
  11. #61
    VY 11 'Redhot' Ute
    Sep 2005
    My vy II s is two years old this month, it has 95,000kms on the clock, this morning it come up with ABS Fault warning, has anyone experienced the same, id say it'd be a warrenty issue but ive only got 5,000kms til that runs out.. i havent had any other problems except for the gf burning the clutch...
  12. #62
    Aug 2005
    warranty Running out???
    Holden's New Car warranty is 175,000/3 year isn't it????
    That's what I'm counting on anyway...
    Well, my girl is going in for first tune/service/check since buying tomorrow, have a list of 18 things to get fixed, tightened, looked at (see below)
    Things Need to Be Done on Car
     Glove Box fixed so light not permanently on
     Rear driver’s side above door handle tightened – driver’s side same – stays down – springs on all of them not working as should.
     Replace cracked rubber on passenger side door
     Handbrake to be tightened
     Tune
     Fluid check and change
     Battery in key – doesn’t respond until very close to car - replace
     Patching paint chips on door edges, scratches around fuel filler,
    two patches on bonnet
     Wheel rub / excessive noise at low speeds?
     Reverse light fixed/Brake light? One of these is broken
     Light in boot, not always working – wiring problem?
     Tighten driver’s footrest, is loose
     Tighten gear knob, having to re-tighten ever couple of days at
    the moment…
     Gearbox intermittent change from 65-80k/p/h – Surging?...
     Brakes? Ok? Very strong “heat” smell on stop. Coming from Rear
    wheels it seems
     On cold start, big ticking from engine – dissipates after about 10
    seconds. Very noticeable, reminiscent of low oil/out of tune older
    commodore, oil checked, levels fine… please explain?
     General engine noise – constant lifter (I think) noise
     Battery? Power used by head deck, flickering head unit when lights
    on, indicating, braking etc. Alternator charge ok? if ok, will be
    getting bigger battery. Deep cycle?
     ** Question about modifications that are allowed whilst still keeping
    holden Warranty.**
    fingers crossed for none of the usual holden stuff ups...
  13. #63
    VYSSM6
    May 2005
  14. #64
    Reaper's Avatar
    Aug 2004
    The warrantee depends on how you bought the car.
    New car is 100,000/3 year, Holden approved 2nd hand car = 175,000/5 year.
    The ticking sound you are hearing is probably the injectors which is normal.
    Reaper
    Quote Originally Posted by Morgasshk
     Tune
    the moment…
    wheels it seems
    holden Warranty.**
  15. #65
    holdensupporter2005's Avatar
    holdensupporter2005 is offline Donating Member
    VE SV6 Commodore - Silver
    Sep 2005
    N.E. Vic
    Anyone else had problems with windows washer. today I used it for the first time since I got the car a week ago, it would go for a few seconds and stop, when the wipers were on high speed it would not go at all (is this normal). I could intermittantly get the washer to work when it was in the slow position only. warranty issue?????
    It is not a blocked tube or washer head. Seems like an electrical fault with the switch.
  16. #66
    VY 11 'Redhot' Ute
    Sep 2005
    My car is covered by the new car warrenty for another 5k, then the certified warrenty kicks in, but ive been burned by a dealer before so i want to get it looked at b4 it reaches 100k, i prolly got a month to two months,
  17. #67
    VY Exec S2
    Sep 2005
    I got my central locking replaced yesterday (rear passenger side).
    That makes both rear doors have new locks lol and i have no problems with them for now.
    Around the 40-70km/h range i sometimes here a squeaking coming from the drivers or passengers side (alternates). Not turnign or anything just cruising, anyone got ideas?
  18. #68
    VY II Berlina
    Jun 2005
    My car is a VY s2 Berlina v6. Anyway i was driving around a corner yesterday and the motor suddenly died, its the first time this has happened. Any idea what might have caused it?
  19. #69
    VYIISS6m
    Sep 2005
    Quote Originally Posted by Reaper
    Reaper
    I have a slight ticking from engine in my VYII SS that comes on while the engine is cold at start, and also occurs randomly when stopped, though its not always there. Hoping that its just injectors as you say, is this common with the GEN3?
  20. #70
    Reaper's Avatar
    Aug 2004
    Quote Originally Posted by vaertigo
    Virtually all multi point fuel injected cars can do it. Some are worse than others. My friend's VP was very loud but he fixed that. My car does it when it's cold but it dissapears quickly. I am talking about a ticking sound here. knocking or other sounds are often caused by lack of oil or pressure which need immediate attention (ie shut the engine down now!)
    Reaper
  21. #71
    VYIISS6m
    Sep 2005
    nah, its nit a knock per se, its more of a tsic tsic tsic sound
    going to holden tomorrow to see what they reckon
  22. #72
    VY 11 'Redhot' Ute
    Sep 2005
    I know the VZ has a major problem with the inacurate fuel guage, does the VY aswell, yesterday i was watching the Distance 2 Empty, it went from 300km left to 310, to 320, then to 420kms left then to 530kms left all in the space of about 25kms...
    I was reading some elses post and they said "it's more like a fuel indicator than a fuel guage, Yeah i thinks there is some petrol in there"
    is there an upgrade for the software and is it covered by warrenty
  23. #73
    Fekason is offline Fekason
    MY11 VE Series II SV6 Manual
    Mar 2005
    Penrith NSW
    Default Distance to Go Detail.
    It is not unusual for the Distance to Go (DTG) to vary, even markedly.
    It works off the fuel tank quantity and the average fuel consumption over a recent period.
    Thus you can do a day or two of peak hour commuting with high fuel consumption, then you head off on a highway (with dramatically better consumption) and the DTG will start to increase.
    On the other hand, you can be driving on the highway and assess that you have enough fuel to get home. However, if the last part of the trip is in heavy traffic, the DTG will start to reduce much faster than the actual Kms.
    The fuel guage problems relate to the fuel guage indications, i.e. showing full when it is not, empty when it is not, running out when it still shows 1/4 tank, etc.
    If you are concerned with your fuel guage, monitor it rather than the DTG.
  24. #74
    Aug 2005
    I think mine has the same issue...
    Back at holden for second time this fortnight...
    another bunch of warranty items... great tech pointed out heaps more stuff i didn't know about...
    rocking seat (electric) getting replaced, bubbled taillights, cracked door rubbers, worn power steering hose, loose gearknob, etc etc etc.
    and also on the joblist is "re-calibre fuel sensor"...
  25. #75
    VY 11 'Redhot' Ute
    Sep 2005
    my Honda legend does that aswell changes with the current consumption, but my fuel gauge was moving in sync with the D2G, it was in traffic aswell not heavy traffic. oh well, back to the drawing board.
LinkBacks (?)
  1. 29-02-2012, 09:39 PM
  2. 29-02-2012, 09:33 PM
  3. 29-02-2012, 09:29 PM
  4. 31-12-2011, 11:49 AM
  5. 05-10-2011, 05:56 PM
  6. 12-09-2011, 05:39 PM
  7. 31-08-2011, 08:00 PM
  8. 31-05-2011, 08:12 PM
  9. 27-05-2011, 04:43 AM
  10. 14-05-2011, 07:21 AM
  11. 12-03-2011, 07:36 PM
  12. 30-01-2011, 09:19 AM
  13. 10-12-2010, 07:47 AM
  14. 16-08-2010, 04:13 PM
  15. 16-12-2008, 06:16 PM
  1. Are the VY's much different to drive than a VX?
    By muso in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-12-2011, 01:13 PM
  2. Need Info: Turbo v6 VY's
    By howie69 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-10-2010, 08:10 PM
  3. My VY's Nose Job
    By Mossman in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-04-2008, 08:51 PM
  4. vy's air problems
    By qector in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-04-2007, 07:56 AM
  5. Learning VY's
    By fxcustoms in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-06-2006, 04:20 AM
