Page 1 of 20 1234511 ... LastLast
Results 1 to 25 of 481
Like Tree2Likes
Thread: Issues with VY'S
    Ratty Guest
    Default Issues with VY'S
    Was thinking abotu starting a thread the Mods could make sticky about issues we have found with the VY'S that could affect everyones car and keep a record of the issue and fix.. this of course would be unoffical and not backed by holden or JC... Thoughts?
    To kick it off these are the issues I have found and have been fixed...
    Ones I have been told effect the range...
    Front ASH Tray hinges need a mod
    Power Steering rack requires a modification on most VY'S to stop SHUDDER at low speed full lock turning
    Door actuators on most VY'S prevent unlocking of the doors esp in cold wet weather...
    Door seal's can leak on some VY'S
    More to come as I think of them...
    VYSSM6
    May 2005
    My VYss suffers the ashtray problem and thats it everything else you mentioned has not been an issue .My major issue is waiting for my rebuilt gem engine cause mines got the death knock.
    Darren's Avatar
    Darren is offline Site Administrator
    HSV Clubsport R8 E2 M6
    Feb 2003
    Consider the thread stuck, I really do like this idea.
    It's handy for me as well as then I'll be able to pick the cars to bits before paying for it.
    Ratty Guest
    VY2 SS
    May 2005
    Auckland NZ
    Default thanks ratty from kiwiss
    thanks - central locks on my VY11 SS occassionally gets "jammed" using keyless entry. Locks only come half way up and need several goes to unlock or have to use key in the doors - and yeah, mainly in cold or wet weather. have been meaning to mention to dealer and will now next service.
    Another mod for the list - had an issue with "brake disk scuff" - if I drove at lower speeds with window down could hear a constant "scuffing" noise from all wheels. quite loud and annoying. turned out to be sticky hand brake shoes (or something like that) and Dealer fitted a mod kit for it and all good now.
    vy v6 acclaim
    Apr 2005
    thanks for the update ratty,just purchased a vy v6 about 3 weeks ago and the only problem i've found so far has been heavy steering, especially at high speed. my previous ride was a vr and the steering was a lot lighter.
    vl_dragon86 Guest
    My old man bought a VY auto a few weeks ago, and the only problem he has is the shudder in the steering. Any ideas on what it is exactly and how to fix it ourselves?? Thanx!
    Ratty Guest
    Yeah I am told its a kit from Holden... basicly longer hoses and slightly larger... gives the oil more room to move... not sure how that exactly fixe's the issue tho... Holden did mine under wrty... known fault.
    04' VY s11 Cosmo "S"
    Jul 2005
    South Eastern Suburbs Melbourne
    Hi guys,
    since picking up my vy S2 S in july 2004, brand spanking from the factory, (had factory sunroof and lsd ordered and also cosmo paint, which dealer had no floor stock) i've only had a problem with the front passenger actuator and now a squeaking when engine is cold. i've been told though that the squeaking is most likely due to the cold weather. i think it could be that, or maybe the idller pulley. is anyone else having the same problem?
    Darren's Avatar
    Feb 2003
    Funny you should say about the squeaking, I started mine up this morning and noticed a squeaking sound, once the engine is warm it appears to disappear.
    I haven't investigated this one yet but my immediate thought was the serpentine belt.
    VY Acclaim
    May 2005
    Glen Waverley
    Default Air Conditioning smell
    When the air conditioning is turned on there is a strong 'musty'smell. Its only when the air conditioning is switched on and is evident when on fresh or recirculated. Smell is not there when air is off. Smell does seem to lessen after a period, or you just get used to it, not sure which.
    Cannot seem to locate the source or why it is just air conditioning related.
    Any suggestions?
    Ratty Guest
    yeah ensure that its draining correctly... there might be trapped water inside getting musty...
    VY Acclaim
    May 2005
    Glen Waverley
    There's always a good puddle under the car after the systems been used and the rubber gromet doesn't appear to be bloked either. There's no unusual fogging of the windscreen when you turn the heater on either. I've had a VR that didn't drain because of a bloked gromet but it never smelt, just overflowed into the cabin and fogged the windscreen.
    Is there a filter of some sought that may be causing the problem and if so, where?
    VYSSM6
    May 2005
    Quote Originally Posted by Darren
    How is the new car Darren.
  15. #15
    Aggro_VE's Avatar
    Aggro_VE is offline The Overseer
    A lazy VE
    May 2005
    Lake Macquarie
    Great idea having this..should have one for all the models, I read this with interest this thread will have a bearing on my decision to get a VYII Berlina or a VZI Exec. By the time it comes to buy I will know more than the dealer about just every issue that has affected the VY's/VZ's. Thanks guys
    P.S. yes Darren, post up some thoughts on it in ya new car thread for us to read.
  16. #16
    Jul 2005
    Quote Originally Posted by Slow_Az
    just an update on this post, i had the car taken back to holden today and they re-aligned the pulleys. i'lll let you guys know if there's still the noise on the next cold start.
  17. #17
    Ratty Guest
    Yeah my fathers VY Does the same thing... found out the waterpump pully was rubbing on the belt (second time we have had an issue with belt rub on is VY) they replaced the pully and belt... all seems to be good atm... they did it on Thursday last week... No issue as yet
  18. #18
    VY 2004 Calais II
    Jun 2005
    ummm, ok...wen i start the engine in passengers side i hear this shuddering noise . In service they told me its from Airconditioning pipe to the passenger side.the fixed it but its bakagain so i have to take the car in again.
    Just put the car in drive mode and youll hear this shaking nose from under neath the air bag...its irretating
  19. #19
    RBMAD Guest
    Default ABS shudder
    Quote Originally Posted by AlX
    Got the same shudder in my VY Berlina, I was told it was the ABS doing a self-check. What did they tell you was causing the shudder? Do they really know :b:
  20. #20
    2003 vy executive
    Aug 2005
    Hi all.........When l start my 2003 vy v6 up the engine occassionally idles rough as though it is running on 5 cylinders and only when cold.Does anyone have the same problem or know what the cause is. Its been back to Holden but they cant find anything wrong with it. HELP!!!
  21. #21
    VY Equipe Guest
    i had that happen only once, they replaced the spark plugs and said it should be it. Has not happened again and it didnt register a fault with the computer, so i hope that was it
  22. #22
    VY Executive
    May 2005
    I'm getting the steering problem with mine. Is this actually something that should be fixed under warranty? As mine is a late 02, I might have to get it back to the dealer rather quickly...
  23. #23
    dreid Guest
    Cheers Mate. I have just bought a VY Wagon, after heavy rain the rear passenger carpets are wet (suspect door seals?). The steering also vibrates at slow turn!!!
    That's two out of four!!!!!
  24. #24
    Morgasshk is offline Morgasshk
    VY Exec 3.8L Sedan 9C1 Pack
    Aug 2005
    I have a lot of road noise coming through...
    Don't know whether it is from the 18 inch wheels, whether they are rubbing, if it is the brakes, just general road noise or what....
    Also seems to have the same problem with the gearbox that my VR had - when going up and/or and cresting hills at about 70-85kph, can't seem to decide between 3rd and 4th gears, and sort of feels like it is dropping in and out of both...
    Anyone else have these issues?
    (I have another issue with birds crapping on my car, but not really the cars fault though!)
  25. #25
    blackgully Guest
    Default Vy Issues
    VY II V6 ACCLAIM....
    shudder from power steering at low speed, seems all have that...
    interior fan seems very noisy (at centre vents) at speed 2 and upwards....
    auto trans has slight whine when in first gear and taking off slowly...
    otherwise just really enjoy driving it !!
LinkBacks (?)
  1. 29-02-2012, 09:39 PM
  2. 29-02-2012, 09:33 PM
  3. 29-02-2012, 09:29 PM
  4. 31-12-2011, 11:49 AM
  5. 05-10-2011, 05:56 PM
  6. 12-09-2011, 05:39 PM
  7. 31-08-2011, 08:00 PM
  8. 31-05-2011, 08:12 PM
  9. 27-05-2011, 04:43 AM
  10. 14-05-2011, 07:21 AM
  11. 12-03-2011, 07:36 PM
  12. 30-01-2011, 09:19 AM
  13. 10-12-2010, 07:47 AM
  14. 16-08-2010, 04:13 PM
  15. 16-12-2008, 06:16 PM
  1. Are the VY's much different to drive than a VX?
    By muso in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-12-2011, 01:13 PM
  2. Need Info: Turbo v6 VY's
    By howie69 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-10-2010, 08:10 PM
  3. My VY's Nose Job
    By Mossman in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-04-2008, 08:51 PM
  4. vy's air problems
    By qector in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-04-2007, 07:56 AM
  5. Learning VY's
    By fxcustoms in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-06-2006, 04:20 AM
