+ Reply to Thread
Results 1 to 6 of 6
Thread: Changing parts between series 1 and 2??
    2004 VZ S-Pack Ute
    Jan 2009
    Gladstone QLD
    Default Changing parts between series 1 and 2??
    Hey guys,
    just asking a quick q for a mate. He was wondering if you are able to swap parts from a series 2 S Pack eg. (S pack cluster, door trims etc) to a series 1 excec commy?
    DUK13Y's Avatar
    DUK13Y is offline Now w/Phreddied Dash DUK13Y Executive
    VYII Berlina, '97 Lancer
    Breakout Champion! Tricky Duck Volleyball Champion!
    Nov 2007
    Sydney, Australia
    I don't think you can swap the cluster as some of the gauges will read backwards. Please someone correct me if i'm wrong.
    A Commodore is a passion. Anything else is just a car
    Sierra
    Mar 2009
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    Quote Originally Posted by crewsy View Post
    for what model commo?
    Gathering it's int eh VY section, i presume Series 2 to Series 1.
    Door trims and all that other stuff yes, bodywork didn't change. However, as for the cluster, not too sure on that one. You might have to change over the BCM as well. But not 100% sure.
    Fekason is offline Fekason Fekason Calais
    MY11 VE Series II SV6 Manual
    Mar 2005
    Penrith NSW
    Default Be Careful!
    The clusters are a straight swap between the same series, though the cluster may need a Tech2 programming at your local dealer to be set to your car.
    As previously mentioned, if you swap S1 and S2 clusters, the fuel guages will work back to front and make your DTE useless. This can be solved by changing fuel sender units at a cost of about $400 (three years ago). Best to make sure that the cluster is from the same series.
    In the VY, the change from single window trip copmputer to three window is a straight forward swap as well provided it is from the same series. A Tech2 programming and away you go. However, the odometer can only be reset to your car kilometres in a new cluster (less than 100 km), unless you take it to an instrument overhaul facility.
    revv_head's Avatar
    revv_head is offline I DRIVE A V6 SS :P revv_head Executive
    VY-SII Commodore S
    Mar 2009
    Sydney, NSW
    hmmm now to find a series II S pack crashed with 20,000 km on the cluster :P
    I own an Commodore, therefore, I own the road
    Oh how i love rear wheel drive
+ Reply to Thread
  1. VN V6 series 2 parts into series 1 ?
    By clubby677 in forum V6 Development And Modification
    Last Post: 17-02-2008, 12:22 PM
  2. series 2 V6 parts into series 1
    By clubby677 in forum General Discussion
    Last Post: 17-02-2008, 11:18 AM
  3. Changing transmission in a vn series 2 auto
    By CSL in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-08-2007, 02:59 PM
  4. changing parts
    By dirkVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-03-2007, 05:20 PM
  5. <QLD> Parts Wanted Please ? Series 1 VN
    By DF_Media in forum Swap / Wanted to Buy / Trade
    Last Post: 04-03-2007, 09:44 PM
