+ Reply to Thread
Results 1 to 7 of 7
Thread: removing front bumper
    VY S2 S Pack
    Jan 2009
    Whyalla S.A
    Default removing front bumper
    how do remove the front bumper on the series 2 vy
    Lumps of cheese's Avatar
    Lumps of cheese is offline catch us if you can Lumps of cheese ClubSport Lumps of cheese ClubSport
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    VY S2 S Pack
    Jan 2009
    Whyalla S.A
    VY SII HBD Calais L67
    Dec 2006
    A mate showed me this recently and now I can have the bar off n on in under 5 minutes
    Have a mate help you cathc the bar or place a towel, rag or bit of cardboard under the bar so it doesn't get carved.
    Undo the 3 screws on top of the grill near the bonnet release, remove the screws in the wheel arches (2 each side from memory) then in the wheel well grab the bumper and pull it towards the wheel and slightly outwards (away from the car) at the same time. Do the same on the other side and the bar will fall away.
    No too sure but I think the S pack has some screws in the lower section of the bar going into the diffuser too that need to be undone before the bar will come away.
    Calais is much easier than S pack lol.
    If you have foggies disconnect them before you start or they can be unclipped as the bar is removed from the reo, whatever's easiest.
    Mak sure once the bar is off you fit a dirty big cooler for trans or power steering and you'll be rocking
    VYII Calais L67
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum Calaber W427 Calaber W427 Calaber W427 Calaber W427 Calaber W427
    VY II BERLINA
    Nov 2007
    LOwer Hunter Region NSW
    Quote Originally Posted by chargedvx6 View Post
    Just one thing to add. Leave the top screws above the grille until last, that way the bar won'd drop unexpectedly.
    The best order is:
    Remove the two little buggers in behind the number plate - they are a fiddle. Usually makes sense to haul off the plate first.
    Remove the lower of the two screws in each wheel arch opening. The upper screw is used to hold the inner guard lining in place and can be left untouched.
    Gently pull each side of the bar away from the guard. They are firmly clipped in place but will release easily.
    Remove the screws along the top above the grille.
    The lower lip spoiler should come away with the bumper and not involve any additional screws. I'm not sure about any "diffuser" set up for sports models.
    danja's Avatar
    danja is offline Swerves for gay koalas danja W427 danja W427 danja W427
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    I strongly suggest replacing the two screw-type clips behind the number plate with the push-type clips used on the radiator shroud and a few other places (on the VZ anyway).
    The part number is GM-92138636 "Retainer front bumper". The bloke reckoned they were actually an Astra part, but I have them all over the car, they fit perfectly and are simply a better design (so they probably are an Astra part actually )
    They cost me $1.24 each.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    Calaber's Avatar
    VY II BERLINA
    Nov 2007
    Quote Originally Posted by danja View Post
    Danja
    Are they the ones that have a large circular head with a small recess on either side, and the pin that pushes in is flat on both sides? If so, I agree - they are a very good clip compared to scrivets.
+ Reply to Thread
  1. removing front bumper
    By _Mukas_ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-11-2007, 12:26 AM
  2. AIR CON Problem, removing front bumper?
    By Gav95VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2007, 02:54 PM
  3. WTB: VK door, front bumper, front right quarter panel
    By craigvk in forum Swap / Wanted to Buy / Trade
    Last Post: 05-07-2006, 04:02 PM
  4. removing front bumper
    By steve40 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 31-03-2006, 07:30 PM
