+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 26
Thread: fitting 20's on VY II Calais
    vyIIcalais's Avatar
    vyIIcalais is offline VYIICalais vyIIcalais Executive
    VY SS
    Nov 2008
    WA
    Default fitting 20's on VY II Calais
    hi guys,
    im thinking of fitting a set of 20's on my vy series 2 calais.
    i rather the look of the 20's than the 19's and thats why im going for that.
    i know with the 20's there may be some problems with fitting them, any heads up on any problems i may encounter and how to tackle them before i do it. cheers
    daniel555's Avatar
    daniel555 is offline Custom VY Commodore daniel555 Executive
    VY Executive S2
    Apr 2009
    Vic, Australia
    Quote Originally Posted by vyIIcalais View Post
    hi guys,
    If your not lowering it, Then you may not have any problems.
    If you are, Gaurds rolled, Camber Kit (Depends how low), Speedo may have to be re-calibrated, Whoever fits then may talk you into getting 235's or 225's, Dont. Its dangerous (Overstreching the tyre, 245's are the minimum load) If you want 20's + low, best option is to get coil over suspension, Well in my opinion anyway.
    Oh, And more expensive tyres.
    Let me know how you go mate.
    08 SSV M6
    Apr 2008
    Central Coast, NSW
    225s are shit, 245s are the go. I got talked into 225s and Im spewing. They are shit, I knew they would be but went ahead with them.
    My ute is on SSLs though and SSSLs are going in, next tyres will be 245s definately.
    Voodoo Blue SSV M6 sedan
    355rwkw
    vyIIcalais's Avatar
    VY SS
    Nov 2008
    WA
    whats so bad about the 225's? i know they are dangerous and stuff but other than that whats the down side? i would prefer to get them cos i personally rekon they look better, but if there are any issues let me know!
    cheers
    08 SSV M6
    Apr 2008
    Central Coast, NSW
    They just dont seem to grip as good as the 245s (I have them on my standard VY SS 18's)
    You notice it especially when you are turning around roundabouts or into driveways etc etc
    Trust me, 245s are better, but its up to you.
    355rwkw
    daniel555's Avatar
    VY Executive S2
    Apr 2009
    Vic, Australia
    FAT.36L's Avatar
    FAT.36L is offline 8,000RPM FTW!!! FAT.36L Hitchhiker
    Turbo S13 Onevia
    Sep 2008
    Maitland
    Quote Originally Posted by pepstar87 View Post
    Good luck mate i run SSSL and 225's and i use to scrub to the shithouse my 225's just fit now 235 wouldnt go close to fitting
    FAT.36L NOW RIDING IMPORT
    Full 5spd Conversion For Sale PM me
    08 SSV M6
    Apr 2008
    Central Coast, NSW
    I got the SSSLs in yesterday, its perfect, the ride isnt rough and the fronts just miss the guards, the rears have plenty of room as the guards are rolled.
    355rwkw
    FAT.36L's Avatar
    Turbo S13 Onevia
    Sep 2008
    Maitland
    Mine are rolled and i had pumped mine aswell and the 225s fit
    i didnt find mine that bumpy with the SSSL's in but i defo need shortened shocks
    vz calais 190KW A5 CHE TUNED
    Feb 2009
    SmithField NSW
    vyIIcalais's Avatar
    VY SS
    Nov 2008
    WA
    245's and 20's though, prob not going to fit that well. i know its probably the right option, but i guess when i buy them and get them fitted ill find out!
    vyIIcalais's Avatar
    VY SS
    Nov 2008
    WA
    daniel555's Avatar
    VY Executive S2
    Apr 2009
    Vic, Australia
    As i said, 245's will most likely not fit on a lowerd VY.
    You gotta do all sorts of things to make 20's fit the right way, not the cheap way.
    vyIIcalais's Avatar
    VY SS
    Nov 2008
    WA
    so 19's are the easiest and cheapest way then i guess..
    but im just not sure whether there big enough for me!
  15. #15
    FAT.36L's Avatar
    Turbo S13 Onevia
    Sep 2008
    Maitland
    19's will cost you more for tyres than 20's cause 20's are more common then 19's
    and if you get 19's with a dish they look like 18's
  16. #16
    vyIIcalais's Avatar
    VY SS
    Nov 2008
    WA
    yeah and i dont want them to look small. @&*k it ill just get 20's, they look better, even though there gonna take a bit more time and effort, and money i guess!!
    fat .36l if i do get 20's do do u suggest i get in the way of lowering, coil over suspension, camber kit, all that jizz? and what did u get done to yours? expensive?
  17. #17
    TMM's Avatar
    TMM
    TMM is offline OEM+ TMM has disabled reputation
    VY V6
    Jun 2008
    VIC
    Quote Originally Posted by FAT.36L View Post
    True, but if you can't afford decent tyres then you shouldn't be buying the wheels in the first place. Then again, 225s fit on 16x7"s and will handle way better then on 20" and the tyres cost half the price... sometimes i wonder why people spend so much and end up with something technically worse.
    </rant>
  18. #18
    FAT.36L's Avatar
    Turbo S13 Onevia
    Sep 2008
    Maitland
    Quote Originally Posted by TMM View Post
    </rant>
    If you want handling dont buy a commodore buy a import or something and due to imports mostly being a turbo a v6 commodore is a common choice for p platers and droping them on 20's is the way to go theses days and yeah its unsafe but how many time s have you herd of a 225 tyre on a 8.5 rim causing a crash or doing damage
  19. #19
    08 SSV M6
    Apr 2008
    Central Coast, NSW
    Dont bother with a camber kit unless it really is cambering!
    When you visually look at my rear wheels, its hardly cambering, so I'm not worried.
    If it starts to wear unevenly over time then Ill just swap the two rear tyres over and then the other side will wear.
    Its not worth forking out $600+ for a camber kit installed unless its really cambering bad.
    355rwkw
  20. #20
    Y-Series Senator Signature
    Jan 2006
    Willall Racing
  21. #21
    one_and_only2004's Avatar
    one_and_only2004 is online now Turbo L98 FTW one_and_only2004 Calais
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    i'd say a camber kit is a must if you're lowering and getting bigger rims - 8000km's absolutely shagged my tires so i put in a fulcrum camber kit (was about 400 installed + supplied), that and it definately gave me a bit more grip.
    VY SX "The Silver Fox" - 237RWKW Blown V6
    VZ Thunder - 360RWKW Turbocharged V8 - Tuned by BPS
  22. #22
    vyIIcalais's Avatar
    VY SS
    Nov 2008
    WA
  23. #23
    daniel555's Avatar
    VY Executive S2
    Apr 2009
    Vic, Australia
    Quote Originally Posted by SIG-054 View Post
    1. Select 20" wheels
    2. Select 245/30 tyres
    3. Guards rolled
    Enjoy.
    If your not lowering it.
  24. #24
    Jan 2006
    Willall Racing
    umm my brother has a vy2 calais and has lowered it on SSL springs with 20's and wears the tyres evenly, and it hasnt got an alignment since it was done.
  25. #25
    TMM's Avatar
    TMM
    VY V6
    Jun 2008
    VIC
    Lol ok whatever. A completely stock V6 with 15/16/17s and FE1/FE2 will smoke another V6 that's been dumped, catback, CAI, 20s... Just sayin' . I think it's hilarious that people get performance mods (CAI and catback on a stock V6 is like trying to get blood out of a stone anyway), then go ruin what performance they had in the first place by fitting a retarded wheel/tyre/suspension combo. I know most people who get 20s do it for the looks alone, but 18s are far cheaper, perform better and the chicks won't even know the difference. The only proper reason for getting 20s is to attract other guys in commodores hahaha
    Don't mind me, i just like to rant about silly mods :P Go ahead and enjoy your 20s if that makes you happy
    It is when your tyres are worth >$2k.
+ Reply to Thread
  1. Fitting 20's to a VR/VS
    By GAMBLR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-05-2009, 09:22 PM
  2. VR Calais V8 on 20's (new pics)
    By YEP-20S in forum VR - VS
    Last Post: 02-11-2008, 09:18 PM
  3. Fitting A Vl Calais Dash Cluster To My Vl!
    By 86VL5spd in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-06-2004, 11:25 PM
