Calaber, thanks for the great instructions.
A couple of extra points to add to help anyone else with the same problem:
1. The metal frame that holds the glovebox in place gets in the way when you try to remove the amplifier. You do not need to completely remove the frame, there is a screw holding it to the blower assembly to the right and below the amplifier that you can loosen and it will give enough play to get the amplifier out.
2. Mine simply had a circuit that the solder had dried on and had come loose (see picture). I soldered it back in place, and refitted it OK. Saved the $80.
