Results 1 to 18 of 18
Thread: Vy.. Ultra low springs wot drop.
    VY Executive
    Jul 2009
    Newcastle
    Default Vy.. Ultra low springs wot drop.
    Hey.. I got a vy exec
    i put a set of ultra lows in the back myself last night.
    Yet to fit the front ones wich are also ultra lows.
    After fiting the back to and taking it if the jack it only dropped 50 mm if that. Still sittin bout 20 mm from top of tyre on stock rim.
    Is there anything i dont know about that is stoppin it from sitting?
    Or any thing else i can do to it to make it sit lower?
    A mate put ultras in him vt and wen he lowerd it off the jack he jack got stuk was so low.
    DUK13Y's Avatar
    DUK13Y is offline Now w/Phreddied Dash
    VYII Berlina, '97 Lancer
    Breakout Champion! Tricky Duck Volleyball Champion!
    Nov 2007
    Sydney, Australia
    Are you 100% sure that they are Ultras and not something like SSL's? Maybe just give it a while to bed in and drop. You might also want a camber kit with those springs.
    A Commodore is a passion. Anything else is just a car
    FAT.36L's Avatar
    FAT.36L is offline 8,000RPM FTW!!!
    Turbo S13 Onevia
    Sep 2008
    Maitland
    Quote Originally Posted by DUK13Y View Post
    Good luck rying to run a camber kit with ultra lows or sssl's tyres will hit guards dramatically
    FAT.36L NOW RIDING IMPORT
    Full 5spd Conversion For Sale PM me
    Adam_88's Avatar
    Adam_88 is offline soon to be boosted
    red VY Ute
    Nov 2008
    canberra
    Adam_88's Avatar
    red VY Ute
    Nov 2008
    canberra
    vz ss and vs statesman
    Mar 2009
    id wait till they bed in and sink down then id put some bigger rims on it will look better after bigger rims
    muttley383's Avatar
    muttley383 is offline Donating Member
    VR 383
    Sep 2007
    3.8 VS exec
    Feb 2005
    Just a thought, someone correct me if im way off...
    But is it possible that because the front is still on stock springs and holding the front end way up in the clouds, that the rear of the car cant settle down as low as it can on the ultra low springs?!...When the front springs go in, the car will be able to settle properly and lower on the springs and go to the correct height.
    VY Executive
    Jul 2009
    Newcastle
    Its definately not hitin bump stops i cut em out.
    I ordered Ultras
    Part number is KHRL 46HD (rear) and KHFL 47SSL (front)
    daniel555's Avatar
    daniel555 is offline Custom VY Commodore
    VY Executive S2
    Apr 2009
    Vic, Australia
    Ultras are only SSL's.
    Might sound stupid, But the springs in right? They should sit around the top of the tyre wall, Maybe a little higher.
    Dunno, Alot of things could be playing a part. Bump stops/Shocks/Spring itself, Basically the whole suspension. lol.
    VYBR8R is offline VYBR8NV8
    VY SS ute 5.7/A4
    Jan 2009
    Port Kennedy
    what shocks you running? i have ultra lows in my ute, i used shortened shocks, got 70mm out of it
    VE SS SPORTSWAGON
    Jan 2006
    Warwick
    wait til you put the fronts in. then the ass will sit. because its still jacked up at the front. plus letting it sit for 12 to 24hrs the springs will settle.
    Adam_88's Avatar
    red VY Ute
    Nov 2008
    canberra
    Quote Originally Posted by JBoags View Post
    these are the equivilant to sl's and are 6mm higher than ssl's i know this coz when i orderd mine i wanted to know what the diference was going to be between sl and ssl
    daniel555's Avatar
    VY Executive S2
    Apr 2009
    Vic, Australia
    Quote Originally Posted by Adam_88 View Post
    No they're not. SL's part number are KHRL-45HD+, And SSL's are KHRL-46HD+.
  15. #15
    VY Executive
    Jul 2009
    Newcastle
    Problem solved i checked it out with king spring. I got sent S/LOW not U/LOW ultra low p/n is KHRL46SLHD for the rear.
    Cheers boys.
  16. #16
    VY Executive
    Jul 2009
    Newcastle
    VY monaro
    Nov 2008
    Wheelers Hill
    ultra lows dont settle 3 inches, they bearly move. If u want low springs i got some but they are rediculously low, just click the link on my signature.
  18. #18
    trentvy's Avatar
    trentvy is offline Dodges raindrops
    Vy S pack
    May 2008
    Kilsyth South
    same problem with my ultra lows mate. my mate had 15 inch stockies on the back and it tucks the **** out of that. and with mine with 18s it just tucks tire
  1. [NSW] VU Ultra low springs
    By Pete SS in forum Parts And Other Items For Sale
    Last Post: 27-05-2009, 11:44 PM
  2. where to buy ultra low king springs?
    By ryan_VX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-11-2006, 05:25 PM
  3. WTB:- Ultra Low King Springs For VS IRS V6
    By timbo_001 in forum Swap / Wanted to Buy / Trade
    Last Post: 07-09-2006, 06:52 PM
  4. ultra low springs
    By hecticvh308 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-10-2005, 09:01 AM
  5. ultra low springs
    By davewgeorge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2005, 11:39 PM
Tags for this Thread
