Results 1 to 10 of 10
Thread: air filters
    CAMMED VY SS Series 2 M6
    Jan 2009
    Whyalla S.A
    Default air filters
    which high flow filters are better out of k&n and Lukey?
    wat power gaisn are expected?
    CANYONERO's Avatar
    CANYONERO is offline Likes Cheese...
    V8 6spd wif MOMO leavaa.
    Mar 2006
    Country SA
    Quote Originally Posted by Macka21 View Post
    personal preferance mate, i got a mate with a lukey in his Vl and swears by it and im running a K&N and i swear by that. i went with K&N because its a proven product, been out there for years and if they reckon its good enough no not void your warranty good enough for me
    a lot of people will say they noticed a heap of power increase and some will say none, i believe my car was a little more responsive after fitting it down low and seemed to breathe better around the 3,000 rpm but nothing extremely noticable. maybe its my mind wanting to believe it is doing something.
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    I went with K&N in mine simply because so many people do it, and very very few people have anything bad to say about them.
    I haven't heard anything bad about Lukey, but I also haven't heard that much from people who use them.
    I'm sure if you were to pull out a K&N and put in a Lukey there would be bugger all difference.
    The truth about the power gains is often stretched a bit, but I believe basic intake mods like this provide a good base to build up on with more serious mods, and you will see results down the track
    vy ss commodore 5.7ltr
    Jul 2006
    i have the factory filter in my vy, but in my vr v6 i put a k&n panel filter in and noticed a better throttle response, might have been a tiny bit more power too, like dvsv8 said personal choice, i don't know much about the lukey filter but i have used k&n and was very good to me.
    VY SII HBD Calais L67
    Dec 2006
    I've used K&N, Lukey and BCM panel filters. K&N and BCM are sprayed with oil and higher flowing whereas the Lukey is a non oil filter and seems to flow about the same as an OEM but is just reuseable.
    A K&N is the cheapest way out IMO, just don't apply too much oil as it gets picked up in the airflow and can coat the MAF wires. This can alter the MAF readings
    VYII Calais L67
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    Yea I would say go with the K&N, i didn't really notice any power difference, but it works out cheaper, the fact that you can clean it and re-use it.
    Gas, Ass or Grass nobody rides for free
    Quote Originally Posted by vsv8berlinawag View Post
    You tell him (coz you are right)
    CANYONERO's Avatar
    Mar 2006
    Country SA
    its not really cheaper if your only keepin the car a year or two, the cost of just the recharge kit is probably more than two new genuine filters........
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Personally I reckon there are plenty of better ways to spend that $100. There's been plenty of people who've actually measured all the restrictions in the various parts of the intake, and they all found that the least restrictive part of the system is the filter itself.
    These are some of the results from one test:
    The difference between the red and the yellow lines is how much pressure is lost through the filter, and the blue line is the total intake restriction. Basically saying that the filter is not the weak point in the system.
    The entire article is an interesting read, and might even tempt you into testing your own car before deciding if the filter is worth it.
    Eliminating Negative Boost
    Part 3 is where they start talking about the results.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    08 VE SS-V 6.0Lt V8 SEDAN
    Mar 2006
    Ive got a K&N and Also a Lukey Filter. I Decided that I didnt like the K&N filter firstly due to the fact that you have to oil them, and secondly, I held the K&N filter up towards the sun and looked through it. I can see through the holes in it. Quite Suprising. An air filters purpose is to catch Dust particles and prevent it from getting into the engine parts.
    I use the Lukey washable one now. It is made of a Gauze type cotton, doesnt need oiling and air flow is quite good. Also it catches the Dust particles very well. If washed on regular intervals ie 10,000Km's or so, it will keep great air flow.
    I noticed that when I had the K&N installed, I saw quite a large amount of carbon/dust buildup in the throttle body after 5,000km's.
    The Lukey one has very little amounts, coming to the conclusion that the Lukey is Filtering the dust better.
    "All of the above is just from my experience"
    VY SS 02, Kawasaki ZZR-600
    Mar 2006
    I didn't even know Lukey were doing filters when I first started buying my K&N's. But I basically like the idea that just give them a quick clean with the K&N cleaning fluid and your right to go again. I also liked the idea of the filter out lasting the car (possible a sale technique but hey).
    Just remember if your going with a cleanable filter to give it a clean at every service (5000 k's) for it to be most beneficial.
    You snooze you lose!
  1. Pod Filters?
    By mike49 in forum V8 Development and Modification
    Last Post: 03-05-2009, 03:50 AM
  2. Pod Filters
    By zoidberg in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2008, 08:50 PM
  3. pod filters
    By fatvgute in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-08-2005, 02:42 PM
  4. K & N filters and the like
    By vsv8berlinawag in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-06-2005, 10:05 PM
