Results 1 to 5 of 5
Thread: vyss manual will not shift into any gear
    vxss vnss
    Jun 2009
    Default vyss manual will not shift into any gear
    vyss will not shift into any gear. does the hydraulic clutch have to be bleed or could it be something else.any info would be appreciated
    VT spac super6
    Nov 2008
    Riverton sa
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    You shouldn't have to bleed the system. All it is is the reservoir connected to the main cylinder which then pressurises the line for the slave cylinder. I would bet my money on something else.
    Fekason is offline Fekason
    MY11 VE Series II SV6 Manual
    Mar 2005
    Penrith NSW
    Default Preesure Plate?
    From my experience, the collapse of the pressure plate will give this symptom.
    vxss vnss
    Jun 2009
    yes,it shifts into gears with the engine not running.
  1. 3rd to 2nd gear shift
    By mina_783 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-10-2007, 01:51 AM
  2. VP gear shift swapping?
    By pow3rslave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-01-2007, 10:14 AM
  3. Gear shift linkage? What?
    By Scooter79 in forum General
    Last Post: 19-08-2006, 09:54 AM
  4. Gear box / shift kit in statesman
    By HIROLLA in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-06-2006, 10:48 AM
  5. Shorten VT1 Gear Shift - Can it be done?
    By davus in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-01-2006, 05:13 PM
