havnt tried or looked yet at them but just wanting a heads up b4 i start info on scuff plates and backseat would be greatfull too
cheers nathan
undo all the screws, remove door lock mechanism, lift off.
"Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
- Theodor Seuss Geisel
On the pull up lock use a sharp blade and pop the red clip out to remove the trigger and single screw behind this to remove the trigger surround.
Then remove the handle surround by using a blade and pop the cap in the centre out and remove the single screw in there.
Remove all the screws that run along the bottom and the inside door jam area and then simply lift up and off.
Just watch out for the power window connections or the power mirror connections, obviously depending on which doors your take off.
As for back seats you just pull the tags on the lower sections in the rear footwells and this dislodges the lower sections, with the lower part taken out you will have access to the two big bolts that need to be removed which are located at the bottom of seat belts, then pull up and off, think there was one somewhere in the centre too..
Scuff plates is basicly a sharp knife to pry the centre mould off the main structure then all the hex screws can be removed from in there, dont recall how many but probaly half a dozen each side.
Good luck.
