Results 1 to 6 of 6
Thread: Recalibration
    VY S Series 2
    May 2009
    workshop, shed, neighbours shed, backyard, someone elses backyard, crushed under jackstand
    Default Recalibration
    Bout 2 put my new diff with set of gears in. What have people done 2 recalibrate the speedo ??
    When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    VY is simple get the dash reprogrammed with the correct PPK for the new diff ratio.
    a holden dealer can do this using a Tech2
    vy v6 ecotec
    Jul 2009
    I work at a holden dealer and yes its just a simple reprograming with tech 2. wat diff gears r u gettin cause some ratios wont match the different options u can choose from
    VY S Series 2
    May 2009
    some 3.7's mate
    Doctor Bob's Avatar
    May 2004
    you dont need to stick to the PPK values in SIP
    you just need to calculate the PPK
    original PPK / original ratio
    then multiply the result by the new ratio
    program the new PPK.
    or check the speed with a GPS & calculate it that way
    Rob
    VY monaro
    Nov 2008
    Wheelers Hill
    i didnt bother recalibrating, mine was about 20km off with 3.9s
  1. diff - speedo recalibration
    By adept in forum V6 Development And Modification
    Last Post: 04-07-2009, 04:06 PM
  2. 20' wheels - Speedo recalibration?
    By finnbe in forum General
    Last Post: 28-10-2007, 01:02 PM
  3. diff gears speedo recalibration
    By jdjones in forum V8 Development and Modification
    Last Post: 02-10-2005, 11:31 PM
