Results 1 to 9 of 9
Thread: Handbreak
    daniel555's Avatar
    daniel555 is offline Custom VY Commodore
    VY Executive S2
    Apr 2009
    Vic, Australia
    Default Handbreak
    G'day.
    Ok, So i went and cleaned my car today, Brang it home and parked it normally, On a slight hill.
    I had to move it as my mum had to get out, Took the hand brake off, then went to park it, went to pull the hand brake up and nothing. doesnt make that clicking noise when pulling it up or anything.
    So any help would be great.
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Sounds like the cable has snapped or the handbrake button isn't disengaging.
    Try taking the handbrake boot off and seeing if the button is working as it should.
    I'm also pretty sure you can get access to the handbrake cable under the center console, though I'm not sure as its been AGES since I've fiddled with a Holden.
    Does it get heavy to pull up as your pulling it up? Or it the lever just moving without any tension?
    daniel555's Avatar
    VY Executive S2
    Apr 2009
    Vic, Australia
    Yeah, gets heavy as per normal. I think you may be right with the button not working.
    How would i fix that? Whole new hand brake lever?
    daniel555's Avatar
    VY Executive S2
    Apr 2009
    Vic, Australia
    Ok, I've found the problem, The button has disconnected from the metal park inside the handbreak if that makes sense. lol.
    I'll let ya know how i go.
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Just a tip...
    When you pull your handbrake up you will hear that clicking sound.
    That clicking sound is the teeth on the hadnbrake clicking. This means you are slowly wearing away the teeth everytime you reef it up.
    Try pushing the button in when you pull the handbrake then release it to lock it in place.
    Might save you teeth in the long run
    daniel555's Avatar
    VY Executive S2
    Apr 2009
    Vic, Australia
    Quote Originally Posted by Ozzie View Post
    Just a tip...
    Yeah, I do push in the button, I was just trying to explain.
    Ok, So i fixed it. The yellow plastic from the button was disconnected to the metal. All fixed.
    This is the part that got disconnected, But its connected in the photo.
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Ahhh yeah. The VY must be different to the VT handbrake, the VT one doesnt want to come out
    Going to have to create a thread and see if anyone knows how to get the VT-VX handbrake button out.
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    '04 vy s series 2
    Feb 2009
    Quote Originally Posted by daniel555 View Post
    okay, how did you fix it ? did you have to buy a part or just put it back ? was it easy to fix ?
  1. Handbreak warning light(and sound)
    By Gaming Warrior in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-04-2010, 10:25 PM
  2. How do i replace the handbreak cable?
    By <atomicL93> in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-05-2009, 10:20 PM
  3. WTB handbreak cable for VL disc to disc
    By broadtail in forum Swap / Wanted to Buy / Trade
    Last Post: 13-07-2006, 10:29 PM
  4. VZ Handbreak Swap
    By Stoobie in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 21-03-2006, 09:02 PM
