Results 1 to 10 of 10
Thread: VY S2 V6 making ticking noise
    VY S2 Executive V6 auto
    Aug 2009
    Default VY S2 V6 making ticking noise
    Hi guys, i have a VY S2 executive V6, and i noticed the other day its making a ticking noise from the passenger side of the engine, but only when the engine is at running temp, it Makes no noise when cold. any ideas whats wrong?? im a bit worryed, thanks for your time
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    top or bottom of the engine ? when was the last time you changed your oil ?? if its black and watery its probably too thin ... or maybe you have a dead lifter or rocker. Both are relatively painless to replace, but change the oil first.
    Aug 2009
    hi thanks for your reply, it sounds like its comming from the bottom of the engine, oil was changed 1000km ago, car has always had regular services and had oil and oil filter replaced every 5000km,
    greenacc's Avatar
    VE Berlina
    Jul 2008
    if its coming from the bottom it could be serious, better have a closer look or get a mechanic to check it out. is it loosing power ?
    Aug 2009
    had a closer look, the noise is comming from the top of engine on the passenger side above the spark plugs, any ideas??
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    probably just your rockers - mine tick all the time.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    VY II S S/C
    Oct 2008
    Liverpool, Sydney
    Is the noise coming from under either rocker cover? If so, could simply be a sticky lifter.
    Aug 2009
    yeah it seems to be comming from the right hand side / passenger side of the rocker cover
    VY Executive
    Apr 2009
    Ive noticed holdens engines are generally noisy annoying as it causes paranioa.
    greenacc's Avatar
    VE Berlina
    Jul 2008
    what oild do you or your mechanic use ?
  1. Ticking Noise
    By chitchat2000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2009, 10:35 PM
  2. YT 1.9/1.95 rockers making a ticking noise
    By CHARGEDVT in forum Yella Terra
    Last Post: 30-01-2009, 02:09 AM
  3. Can anyone help? Ticking making me go crazy!
    By Emackulation in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-10-2006, 10:01 PM
  4. ticking noise
    By krisjanik in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2006, 06:44 PM
  5. motor making ticking sound
    By TINYTIM in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-06-2006, 09:47 PM
