hey all i have a VY series 2 equipe with factory reversing sensors which are playing up.when u put it in reverse sometimes they work sometimes they dont.When they dont work if i press the horn they work instantly.Does anyone know if they are on the same relay or if this is just a coincidence.
Cheers Matt
If they are setup anything like my factory add on kit it should be getting its power and activated by the reverse lights.
do you think the reverse light switch could be faulty or a power problem
Could be either, it could also be a loose wire connection. best to check all the wire connections behind the boot lineing on the drivers side.
