Results 1 to 2 of 2
Thread: Vy powersteering pump
    VZ SS Thunder 6L
    Jul 2008
    Castle hill
    Default Vy powersteering pump
    Hey guys,
    Turns out i need to replace my powersteering pump, i've had all the pipes and seals replaced and i'm still leaking power steering fluid.
    I've been quoted roughly $450 to replace the pump (parts included) although i've found this on ebay
    Commodore 6cyl Power Steering Pump VN VP VR VS VT VX VY - eBay Other Suspension, Steering, Suspension, Steering, Car Parts, Accessories, Cars, Bikes, Boats. (end time 19-Aug-09 20:35:14 AEST)
    Correct me if that's not the part i need or if there's more involved. Too me $350 seems a little steep for labour.
    Is there that much involved in replacing the pump? If not, would you suggest i give it a go myself.
    Check out my ride!
    minux's Avatar
    minux is offline Infidel Bear
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    Power steering pump is a breeze, undo low pressure line and drain fluid out of reservoir, remove fluid container,undo high pressure line, undo 2 bolts between pulley pull pump out, replace o ring seal on high pressure line, reverse procedure to re-install and bleed(not sure about v6 procedure, i'd imagine it would be no different.
    Cost me $180 for new PS pump for a VY Senator, took 2.5 hours to replace alternator and power steering pump from start to finish including getting new pump/alternator.
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
    - Theodor Seuss Geisel
  1. Powersteering pump VS V6 Statesman fix
    By fixedit in forum Holden Commodore How-To's
    Last Post: 07-02-2012, 09:49 PM
  2. powersteering
    By LTHL-VP in forum General
    Last Post: 29-04-2009, 02:55 AM
  3. Powersteering pump stuffed?
    By Apoc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-08-2006, 06:10 PM
  4. powersteering pump
    By anfsvl in forum Parts And Other Items For Sale
    Last Post: 16-04-2006, 01:24 AM
  5. powersteering
    By ultimate_vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-04-2006, 11:00 AM
