Page 1 of 3 123 LastLast
Results 1 to 25 of 74
Thread: Pulling to the left.. why?
    VY II S S/C
    Oct 2008
    Liverpool, Sydney
    Default Pulling to the left.. why?
    Hi guys,
    This problem started occuring a few months after I had purchased my car. It's an on going issue, and I would like to have it solved, but no one can seem to do anything about it. Which, of course, is quite unfortunate, and is making me more upset as the days go by.
    Basically, my car (04 VY II S) is pulling to the left. No matter the speed, the road, the conditions, etc - there is a constant pull to the left. I have to drive with my steering wheel at a rather awkward angle, and have a hold of it at all times (sounds logical, I know, but even a split second of letting go of the wheel will send the car into the left lane, or off the road).
    I've done the following in an attempt to rectify the issue:
    - 3x wheel alignments, at 3 different establishments
    - 4x new tires
    - Rotated tires, several times
    - 2x new engine mounts
    - 2x new rear shocks (don't even know why I gave that a shot)
    - New caster road bushes
    - New sway bar rubbers
    - New radial rod bushes
    I'm at a complete loss as to what I could try next. This has turned out to be a rather costly, time consuming and stressful issue. Could anyone recommend any advice? Would be greatly appreciated.
    Thanks guys.
    shiftySLE's Avatar
    shiftySLE is offline The Lion will never Die!
    VH SLE, VZ Acclaim
    Jun 2009
    Can you garantee it hasn't been in an accident or even a stat write off and repaired by a half ass panel-beater, are the struts bent putting out camber?
    VY II S S/C
    Oct 2008
    Liverpool, Sydney
    I can't guarantee that, no - given the fact that I know it was involved in a relatively low speed front ender - cosmetic damage to the left (coincidence?) headlight and 1/4 panel.
    The car was purchased from someone I know, and I had seen the damage that was done to the car - not enough to justify structural damage, I would have thought. Do you think it's worth checking out? Where should I take the car to have such a thing looked at?
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    shiftySLE's Avatar
    VH SLE, VZ Acclaim
    Jun 2009
    see if the VIN has been recorded through your reg branch, otherwise what are the reasons the wheel joints are giving you for not working it out, just a thought, you have changed a lot of bushes for radial/castor rods whatever but are you sure the rods themselves are not bent, is one tyre wearing more than the other or are they wearing more on the inside or feathering, any tell-tale signs at all of anything
    VY II S S/C
    Oct 2008
    Liverpool, Sydney
    Thanks for the replies guys.
    I'm not familiar with RACV? Who are they? : \
    Two places were at a complete loss, one place told me that a 4 point camber kit may be worth while. Not sure why, though - I thought the VY II S came with the ability for a camber adjustment? I've really struggled to get these establishments to even speak to me a second time - they treat my car as if it is just a nuisance - too much work. I don't know. It's actually quite saddening that I cannot get to the bottom of this. : (
    Just further to that; all tires seem to be wearing evenly. Not too sure if the rods themselves are bent.
    Nov 2005
    Warrnambool
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    RACV is comapred with NRMA up in NSW juzo :P Totally different. RACQ in Queensland, RAC in WA
    MaN|aC's Avatar
    MaN|aC is offline Donating Member
    VT 4.2 S/C
    Apr 2006
    Did you get a print out of the wheel alignment specs? if so post it up
    208rwkw 13.5 @ 102MPH
    STROKED AND BLOWN
    VY II S S/C
    Oct 2008
    Liverpool, Sydney
    I do have a wheel alignment print out - several, in fact. I don't have access to a scanner at the moment, so I will take the latest print out into work tomorrow and scan it there. I'll post it up as soon as I can.
    Say something other than cosmetic damage had occurred during the front ender, what would have been damaged exactly? Anything that I could be looking at exactly, based on the symptoms I'm experiencing?
    Thanks for all the help thus far guys.
    MaN|aC's Avatar
    VT 4.2 S/C
    Apr 2006
    VY II S S/C
    Oct 2008
    Liverpool, Sydney
    Hehe. I tried that prior to submitting my previous post. Unfortunately, the print out was done on some old school forms printer, and as such, the ink is rather faded - it's not even readable, even on a high resolution shot. : (
    MaN|aC's Avatar
    VT 4.2 S/C
    Apr 2006
    Ive been doing wheel alignments for 5 years now, for a VY I usually set it at;
    Fronts either side at
    camber -0.30 degree
    toe + 1.3mm
    castor* isn't adjustable unless it has aftermarket bushes, but prefer 1/2 degree more to the left hand side
    Rear
    camber - isn't adjustable but it should be around -1.30 degree either side
    toe + 1.5mm
    STROKED AND BLOWN
    VY II S S/C
    Oct 2008
    Liverpool, Sydney
    Thanks for the info mate - most appreciated. Do you mind if I scan this print out tomorrow, and send it your way for your expert analysis? : )
  15. #15
    MaN|aC's Avatar
    VT 4.2 S/C
    Apr 2006
  16. #16
    vy ss series1
    Feb 2009
    i'm going through the same deal with my vy ss at the moment, ( luckily i work at a tyre joint doing wheel alignments). i've done pretty well the same as you but i have noticed some set-back issues on the rear, it now looks like the next plan of attack for me is the rear cross member bushes as i've just started to get some axle tramp issues i'm also going to put in the nolathane diff insert.
    Maniac, do you get any inside wear with only 1.3mm of toe in i'm finding that up here in cq we're putting in about 2mm?!
    I may be crazy, but, i am happy about it!!
  17. #17
    VY II S S/C
    Oct 2008
    Liverpool, Sydney
  18. #18
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Enhanced report for clarity (attached).
    Attached Thumbnails Attached Thumbnails Pulling to the left.. why?-wheelalignmentreport.gif
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
  19. #19
    VY II S S/C
    Oct 2008
    Liverpool, Sydney
  20. #20
    Silver VY SS UTE
    Mar 2005
    Moe
    Hi All
    Im suffering from the same thing .. bought 4 new tires and had a wheel alignment . Now it pulls to the left .. Had it back 3 times and still no better .. Let me know if you find out the cause ..
  21. #21
    VY II S S/C
    Oct 2008
    Liverpool, Sydney
    Hi Harry,
    As per the posts above, I think (in my case, at least), my issue may be attributed to a structural defect which occurred during the front ender that my car had prior to me purchasing it. It has gotten progressively worse over time. This may be something worth checking out on your end, as well?
    Can anyone recommend a place at which I could get potential structural problems investigated? Would a place like Pedders be able to handle such a task?
  22. #22
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
  23. #23
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Quote Originally Posted by impulsive View Post
    try a wheel alignment first
    that you have tried after reading this thread.. my bad.. check for bends in your steering arms lol, 'I'll try again
    Life starts at 200km/h
  24. #24
    MaN|aC's Avatar
    VT 4.2 S/C
    Apr 2006
    Quote Originally Posted by foo27 View Post
    With half a degree negative camber +1.3mm doesn't wear the inside edge, I usually work off the camber to set how much toe it needs.
    jameswh, the specs doesn't really show why its pulling to the left. The castor is good, it has very little toe which means its going to wear the inside of the tyres a little and the camber I would .20 more negative camber on the left hand side.
    STROKED AND BLOWN
  25. #25
    MaN|aC's Avatar
    VT 4.2 S/C
    Apr 2006
    double post
    STROKED AND BLOWN
  1. Pulling radiator out
    By james_vrII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-12-2008, 10:45 AM
  2. VP: Pulling the V6 out
    By The_Monk in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-03-2007, 12:33 PM
  3. vx Calais pulling to the left
    By PANZER in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-11-2006, 12:32 AM
  4. Pulling to the left
    By MikesVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-10-2006, 10:21 PM
  5. pulling apart dash
    By VL-187 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-01-2006, 10:24 AM
