Results 1 to 4 of 4
Thread: power gain from a 10 psi pully
    VY II S pack commodore S/Charged
    May 2009
    Default power gain from a 10 psi pully
    hey a mate of mine is gunna make me a 10 psi pully for my VY S/C S pack what sort of power gains can i expect an what will this do 2 my fuel economy
    VY SII HBD Calais L67
    Dec 2006
    The off the line punch will be much better and fuel economy will be better than stock because there is more readily available power with less throttle. Trick is not to mash it everywhere.
    What pulley is your friend "making"? Hope it's 87mm
    VYII Calais L67
    May 2009
    2004 VY2 SV8 A4
    Jun 2005
    Victoria Point, Brisbane
    What sort of power gain? "monstrous" would be a good word
    Fuel economy on the L67 will not be affected by a change in pulley size, unless you put the boot in. Normal easy driving is off boost due to the bypass valve on the M90 blower, but of course when you put the boot in, the valve closes, boost builds, and with the boost on you will use more fuel because there is more air going in.
    So drive gently, fuel economy will remain good, but fang it everywhere, and it will be worse.
  1. SV6 Power Gain
    By kicker12 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 23-12-2008, 11:28 PM
  2. better power gain?
    By nado69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-12-2006, 01:55 AM
  3. VT V6 Mods and Power gain
    By ecotec in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2006, 02:56 PM
  4. power gain 5 litre
    By totality in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-08-2006, 03:29 PM
  5. power gain chip
    By Braddy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-08-2005, 09:28 PM
