Results 1 to 7 of 7
Thread: glazed brakes
    vy executive s2
    Jul 2008
    Default glazed brakes
    what can i do to take the glaxe off my brakes, i took it to the mechanic and said he had done it but if it came back to do some heavy braking and it will be fine, surely there is something else i can do other then leaving some tyre marks on the road.
    VE SS SPORTSWAGON
    Jan 2006
    Warwick
    Quote Originally Posted by paynetrainvy View Post
    heavy braking does not mean locking of the brakes. you should be thinking, why is it glazing in the first place.
    VZ AWD One Tonner
    Jul 2006
    Take the pads out and give them a light rub on some concrete...
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    VS Clubsport series I, VY II R8 Clubsport
    Jan 2008
    Sunbury, Victoria
    Quote Originally Posted by gslrallysport View Post
    This is the best way I have found to get rid of glazing also...nice and easy and works great!
    vy executive s2
    Jul 2008
    Quote Originally Posted by VTPREDATOR View Post
    im not braking heavy or over using the brakes, i drive alot on dirt roads since i have changed jobs and its only started since then. i alos changed the pads and rotors all round just before starting this new job. no mate im not going around locking the brakes up or being rough with them
    VY ute
    Jun 2009
    Is it happening on every wheel? have you checked that none are sticking whils the car is off the ground? could be a faulty master cylinder which you will not notice without the engine running... other than that i have no idea... especially if you have 'normal' driving habits.
    2004 VY2 SV8 A4
    Jun 2005
    Victoria Point, Brisbane
    As above, removing glazing on the brakes is as easy as sanding them a little to roughen up the surface. Needless to say, if it keeps happening, it would be a good idea to investigate why. As above, the brakes sticking for any reason could be causing it, and will also be hurting fuel economy.
  1. Glazed rotors Brake work
    By RunninWild in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-10-2008, 01:04 PM
  2. Drum brakes to Disc brakes conversion
    By sheepz89 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-09-2008, 09:34 AM
  3. Brakes
    By Phoenix21 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-08-2006, 05:49 PM
  4. rda big brakes kit
    By H.I.M666 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-08-2006, 01:10 PM
  5. VK Brakes
    By big_c_43 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-07-2006, 09:28 AM
