Results 1 to 4 of 4
Thread: problems starting
    VY Executive
    Apr 2009
    Default problems starting
    My vy is sometimes cutting out when first starting i turn the key it starts to kick over then absolutely nothing just cuts out. Happens maybe 1 out of 10 starts i feel its getting a little worse aswell. Any suggestions?
    VY ute
    Jun 2009
    Sounds like you could have a dodgy connection somewhere.. does it struggle to wind over at all??
    VYII Equipe S/wagon V6
    May 2009
    Melb, Vic
    Give the FOB ring around the ignition, a light rub with some very fine abrasive, also clean the FOB terminal on the key and see if that makes a difference
    Cheers,
    Dave
    2004 VY2 SV8 A4
    Jun 2005
    Victoria Point, Brisbane
    This could also be bad contacts in the starter solenoid, but best to try the above suggestions first as they are free.
    Not to mention I have not heard of this happening on a commo, but it did happen on my partner's Soarer.
  1. VR V8 starting problems
    By jasonb in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-11-2006, 11:54 AM
  2. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  3. starting problems
    By tgolds1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-08-2005, 03:18 PM
  4. vp starting problems
    By driver in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-04-2005, 12:11 PM
  5. vt problems starting
    By Rick Ballinger in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-01-2005, 01:15 PM
