Results 1 to 3 of 3
Thread: PLugs and leads
    Crewman VY 2 SS
    Aug 2009
    Default PLugs and leads
    This is probably a silly question but I was attempting to check my plugs over the weekend but found I was unable to get the leads off. I pulled and pulled on the metal shroud on the nearest and easiest lead, eventually it moved a little and I could see what looked like a spring inside begin to appear. I quickly pushed it back and decided to leave it.
    Is there a method to getting them off and is the metal shroud ment to come off?
    I have the coil over type system on a VY Crewman SS2 03 model.
    I can also see that at the end of the leads where they go into a rubber shroud at the plugs end that when I move the lead a bit of the internal wire shows?
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    You were going it right, just pull and they will come off. They can be pretty tight sometimes, and it helps to twist the plug a little as you pull. Be careful not to pull from the lead itself though, always the base/plug, otherwise you'll pull the lead clean off the plug.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    as he said just pull and twist the metal or rubber boot. If you break a lead you can buy a new one...
LinkBacks (?)
  1. gas plugs and leads
    By kasey375 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-06-2006, 08:31 PM
  2. PLUGS and LEADS
    By statesman_wagon89 in forum V6 Development And Modification
    Last Post: 30-03-2006, 03:03 PM
  3. Plugs/Leads
    By Spyper in forum General
    Last Post: 27-12-2005, 11:19 PM
  4. Plugs and leads
    By SS57 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-10-2005, 11:06 AM
  5. plugs and leads
    By savage1987 in forum V6 Development And Modification
    Last Post: 06-06-2005, 05:54 PM
