Results 1 to 13 of 13
Thread: Sway Bar
    Crewman VY 2 SS
    Aug 2009
    Default Sway Bar
    I have a crewman VY2, I have noticed that it does not have a sway bar across the struts, did they not fit them on crewmans or is mine missing?
    The ID Plate under the bonnet also just says VY not VY2 so maybe it is not a Mark2? How can I tell?
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Quote Originally Posted by Joshren View Post
    I assume you are talking about the strut brace across the top of the suspension towers under the bonnet? They were only standard on SS's I think - all VY's had the bolts installed ready for the brace, but you have to buy and install it yourself.
    Crewman VY 2 SS
    Aug 2009
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    well i guess they don't come on the SS crewmans then. I think they're only $55 from holden if you're interested. I've got a whiteline adjustable strut brace in the ute - it looks shiny and depending on who you listen to it's either useless or SUPER AWESOME for handling.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    VY SII HBD Calais L67
    Dec 2006
    Have you got 2 little threaded studs sticking out of the strut tower next to the strut top mount? If so it's a VY2 and these are the mount points for the Holden VY2 strut brace which as the other guy said is around $55 from the dealers. Slide it on, do up the 4 nuts and you're away
    VYII Calais L67
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    Quote Originally Posted by chargedvx6 View Post
    Weren't those bolts also fitted to Series 1 VY's and maybe even earlier models? I didn't think they were only introduced with Series 2's.
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    HoldenOnn's Avatar
    HoldenOnn is offline Roll Cage Territory
    VZ Calais Alloytec190
    May 2009
    Busselton, WA
    These are the bolts you need to look for....see pic below. If you do have the bolts already on the strut tower, then you just need to buy the strut brace from Holden with the 4 nuts and install it in about 2 mins.
    As said already, strut brace is relatively cheap. Retail price from my Holden dealer is $59 for brace and $5.50 for 4 nuts. If you can get trade price like me, then its cheaper again
    Part Numbers are;
    Strut Brace: 92112662
    Nuts: 11086952
    minux's Avatar
    minux is offline Infidel Bear
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    Quote Originally Posted by TMM View Post
    VY1 definitely don't have them. Not sure about pre-VY.
    My VY1 Says you are wrong.
    OP, Do not care if it doesn't have them, you DO NOT need them. A strut brace is about as useful tits on a bull.
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
    - Theodor Seuss Geisel
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Perhaps useful for a car that sees the track regularly, less so for a street car.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    minux's Avatar
    Feb 2005
    Quote Originally Posted by danja View Post
    Hate bringing up old arguments, but the setups holden use etc do not even do anything on a track. In fact 2 point braces have been proven to cause more damage due to incorrect force on strut towers. Only way to use them is a 3 point like most race cars use.
    danja's Avatar
    Jan 2006
    Oh if looks are anything to go by the Holden one has about as much structural integrity as a coathanger. I was talking more about the theory behind strut braces - in theory they only provide significant benefit at very high and repeated cornering loads.
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Quote Originally Posted by minux View Post
    Yours is a HSV though isn't it? Exec/Acclaim/Berlina/Calais/S-pack VY1 don't have them. I'm assuming SS Sedan & HSV do.
  1. VN sway bar> replace with VS sway bar?
    By GTP 85 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-08-2009, 08:11 PM
  2. sway bar
    By murph_1989 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-03-2009, 11:07 AM
  3. VT Sway Bar
    By Explosions Hurt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-04-2008, 06:20 PM
  4. sway bar...
    By nmj in forum General Discussion
    Last Post: 02-05-2006, 05:25 PM
  5. Best Sway Bar
    By death-from-above in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2006, 05:53 PM
