Results 1 to 4 of 4
Thread: Vy handbrake wont work/no reverse lights
    vs accliam
    Oct 2005
    Default Vy handbrake wont work/no reverse lights
    Help needed... Vy ute
    1. How do i tighten up my hand brake so it will hold?? Atm it works but not enough to hold car..............
    2. My reverse lights wont come on they started coming on then off but now when i put it in reverse nothing.. Can be tricky at night not seeing....
    Any help would be great .. If i can do it myself and learn how to fix these probs rather than paying through the roof with a auto electrican
    daniel555's Avatar
    daniel555 is offline Custom VY Commodore
    VY Executive S2
    Apr 2009
    Vic, Australia
    Handbrake, Take the plastic trim thing off with a screwdriver (Flick it up) then slide the rubber case off, And you'll see a screw and nut, It'll look kinda long, Tighten it there.
    As for the reverse lights, Dunno.
    VY SS Ute
    Aug 2008
    Hmm interesting about the hand brake, I've tightened the cable up but still no hand brake, I believe there is something else I need to do under the car but not sure what, can anyone fill me in on what else I need to do?
    VYII Equipe S/wagon V6
    May 2009
    Melb, Vic
    Reset that adjustment back and take of the wheels, brakes and rotor/hub check for operation... Adjust if necessary or replace failed/worn parts.. Once you're looking at it easy to see how it all works
    Cheers,
    Dave
  1. Reverse lights not working on reverse
    By macca_223 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-01-2010, 11:02 PM
  2. reverse lights wont turn off
    By kasey375 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-06-2006, 08:31 PM
  3. Handbrake not effective in reverse
    By Tony2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-07-2005, 07:58 PM
  4. Reverse lights don't work?
    By iamwellsie in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-05-2005, 09:10 AM
  5. Vh Reverse Lights Only Work In Drive Gear??
    By BoboRobbo in forum Electrical Wiring / Questions
    Last Post: 14-04-2005, 09:05 PM
