Results 1 to 17 of 17
Thread: VY Steering Wheel
    binghy is offline Matty 038
    Vy Equipe Series 2
    May 2009
    adelaide
    Default VY Steering Wheel
    Hey all can anyone recommend someone in Adelaide besides HOLDEN that could change my steering wheel for me as i purchased steering wheel off e bay.
    Cheers Matt
    2004 VZ S-Pack Ute
    Jan 2009
    Gladstone QLD
    Hey mate do a search for steering wheel and you should find a how to on removing the steering wheel. I did this the other day and was quite easy, just follow the steps! good luck!
    Vy Equipe Series 2
    May 2009
    adelaide
    Thanks for that i am concerned about the Airbag going off or wrecking the Clock spring is there any tricks u can suggest
    Cheers Matt
    2004 VZ S-Pack Ute
    Jan 2009
    Gladstone QLD
    Hey buddy yea sure things, if you follow those steps here:
    Guide to removing vy/vz steering wheel
    As long as you remove the negative off your battery ( I wrapped mine in a plastic bag for extra safety ) and while you remove the bag be gentle dont rush or tug at it (Gentle is key) there is not a lot that can go wrong. Also once you have the bag disconnected (Yellow Plug ) Place it outside face up away from everything again just a safety thing.
    As for the clock spring I did break mine (OOPS!) but i got a new one and was fine. The main thing is that when you go to start this make sure you wheels are perfectly straight! Once the wheels is off dont move anything! simply reconnect plugs and bolt the wheel back on making sure the clock spring behind isnt crushed and sitting correctly. Do the bolt up firmly but not to dead tight! I did this and it became stiff... could have been my spring but! as i said just dont move the clock spring or slip ring once you remove the old wheel and you should not have any problems. Worse case you have to buy a new slip ring which is like $50 (I have one sitting here if you need it) Main thing is dont force anything and be patient!
    Hope that helps!
    2004 VZ S-Pack Ute
    Jan 2009
    Gladstone QLD
    Oh yea forgot to add! Dont turn your car on in anyway until you reconnect the airbag! VITAL! i did this and got an SRS fault! cost me $50 to get it cleared! as long as its connected when u start it will be all good!
    Vy Equipe Series 2
    May 2009
    adelaide
    2004 VZ S-Pack Ute
    Jan 2009
    Gladstone QLD
    Good lucky buddy but yea take it slow you will be fine give me a PM and i will help in anyway i can.
    VY S L67
    Nov 2007
    Quote Originally Posted by Burto89 View Post
    owned.
    it takes 2sec with tech 2 and should be free!
    VY s m5 supercharged
    Aug 2008
    Quote Originally Posted by taztassio View Post
    owned.
    Hahahahahahahahaha holden do somthing for free hahahahahahaha
    my local dealer charged me for work they didnt do
    sp001in's Avatar
    sp001in is offline vyma100
    MALOO R6
    Jul 2005
    QLD
    read the guide, helped me. you need a 30mm socket for the securing bolt. disconnect the battery. leave it for 15mins before doing the work.
    DO NOT RECONNECT THE BATTERY UNTIL ALL THE WIRES ARE RECONNECTED ON THE STEERING WHEEL.
    you'll need a flat blade screwdriver to remove the horn pad. it's tricky but you'll get it. and the airbag wire. the yellow one. lifts off, it doesn't slide off like it looks like.
    Check out my build <---Click me
    Now sporting ASR audio interior lighting and stereo mods, and MACE induction mods.
    Need your computer tuned, or dash calibrated??? Want your PS3 fixed, or wish to prevent the YLOD?
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    You'll be fine mate. I put the guild up because i felt that most people would be able to do it hassle free and that's pretty much what has happened. Just follow the instructions and you'll have your wheel off in no time.
    2004 VZ S-Pack Ute
    Jan 2009
    Gladstone QLD
    binghy how did you go? not really that hard aye and as stated above if you have the correct tools sooo easy!
    As for getting it done for free??? Holden are a mob of rip offs and would of charged me like $100 so i got my mechanic who services my car with a scan tool to do it quickly.
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    Quote Originally Posted by sp001in View Post
    to be safe do it.
    i've never waited, its always been disconect the battery and get straight to it.
    Chev badges are an instant fail
    2004 VZ S-Pack Ute
    Jan 2009
    Gladstone QLD
    Quote Originally Posted by ashbox View Post
    to be safe do it.
    Thats all very well for someone who is confident to work with the airbag, the 15 min rule is simply an extra safety thing so people can feel more comfortable. Ofcourse not everyone does it i personally disconnect the negative and pump the brake till they go hard then work away.
    BTW OP how did you get on with the new wheel?
  15. #15
    Vy Equipe Series 2
    May 2009
    adelaide
    All done no worries just took my time and folloewd the guidelines Thanks to all for ur advice
  16. #16
    Nov 2005
    Warrnambool
  17. #17
    2004 VZ S-Pack Ute
    Jan 2009
    Gladstone QLD
    Great to hear mate!
  1. Boss kits for VT steering wheels to fit a VZ/VY steering wheel?
    By nEb. in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-12-2011, 07:28 PM
  2. cat steering wheel
    By jdls1 in forum Car Audio
    Last Post: 30-08-2009, 11:44 PM
  3. after market steering wheel made steering crap!
    By jet_pilot in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2008, 09:07 PM
  4. steering wheel
    By sulley in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-04-2006, 01:18 AM
  5. Your thoughts on replacing steering wheel with airbag to a MOMO wheel....
    By *VOLATILE* in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2006, 08:36 AM
