Results 1 to 5 of 5
Thread: Rattling engine noise
    VY Aclaim Wagon
    Aug 2009
    Default Rattling engine noise
    Pronounced rattling noise from the engine when cold, reduces as temp comes up, also a constant ticking sound at all temps, VY ecotec in a series 1 Acclaim. Any ideas anyone?
    VYII Equipe S/wagon V6
    May 2009
    Melb, Vic
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Injectors can also get a bit "ticky"
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Nothing like the old screwdriver stethascope to localise engine noises. Try placing the tip of a full metal shaft screwdriver (the type that has the shaft going right through the handle so that you can belt them with a hammer) at points along the rocker covers while you place your ear on the other end. You will soon localise the rattles.
    The same test can be done with the injectors - just don't get near the electrical terminals. You will soon discover the sort of noise that each item makes and be able to identify which one is noisier than the rest.
    Ticky injectors are no big deal if the engine is running well.
    vy ss commodore 5.7ltr
    Jul 2006
    yeh like mentioned above ticky injectors no big deal, sounds like lifters or maybe a dry/damaged rocker and as the oil and temp comes up it fades a little.
  1. rattling pulley engine noise when idleing
    By Rider5 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-05-2009, 06:54 PM
  2. VR Commodore - rattling noise from front of engine
    By mar06mir in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-03-2009, 10:38 PM
  3. Vibrations under 1000 RPM, rattling noise from engine
    By Steery in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-07-2008, 03:21 PM
  4. God almighty rattling noise
    By FREESTYLE_MX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-09-2006, 04:22 PM
  5. rattling noise?
    By comtim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-04-2005, 10:40 PM
