Need help my Vy petrol door wontt close any tips on this please
Does it push in flush with the body but won't stay in place? Is the catch in the body opening stuck inside its housing? It might only need a small amount of WD40 to release if it's stuck in there. Does the door release cable operate correctly when you pull up the release handle - can you feel spring tension and does the handle pull back to its normal position when you release it?
