Results 1 to 9 of 9
Thread: Vy Shuddering (Handbrake?)
    VY Clubsport
    Sep 2009
    Default Vy Shuddering (Handbrake?)
    I have a VY Clubsport when driving slowly it shudders feels like the handbrake is grabbing off and on, mainly drivers side sometimes passenger the only way to stop it is to drive around a carpark with the handbrake on, yes has been adjusted properly with new disks. Does anybody know what this is
    Thanks
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    I would say your LSD is "chattering" . Its either worn out or try changing the diff oil & add some Penrite LSD additive to it as well.
    VY Clubsport
    Sep 2009
    Cool Thanks for that, its nearly due for a service might do that at the same time
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    castrol saf-xa is a direct fill oil for holden and ford lsd's, you dont add any modifiers to it, as they are allready in it
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    Sep 2007
    I wouldnt use Castrol on a Farmyard Gate ,let alone a LSD unit. Penrite Limslip 80-140 is the go!!!! Plus a container of Penrite Limslip additive . They are both Liquid Gold!!!!!!
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by colgf View Post
    and then penrite oil is better than castrol why? if it was better why would you need to add the friction modifier,
    a name and advertising commercial dosnt mean a product is better
    Sep 2007
    Quote Originally Posted by andyman View Post
    The additive is a Penrite recommendation for extreme heavy duty use , racing, & for noisy chattery LSD's. Just ask any reputable Diff repairer (Aussie Diffs at Gold Coast or Northside Gearboxes & Diffs at Brisbane for example) what they use & recommend, besides that ,it's dearer - so it's got to be better!!!!
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    oh man for sure, cant go better by ripping yourself off
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    its not penrite recommended additive, holden reccomend it with there lsd's early on, then castrol released an oil that has the friction modifiers allready forulated in the oil, then for some reason holden recommends that oil for lsd's,
    every buisness will recommend the oil brand they stock
  1. shuddering vs
    By plookyvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-03-2009, 11:24 AM
  2. VL shuddering.
    By langer_and_mash in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-11-2008, 06:13 PM
  3. shuddering
    By Panama in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-08-2007, 10:38 PM
  4. Shuddering
    By kim_08 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2005, 01:34 PM
  5. Shuddering VK
    By haloeight in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-06-2005, 08:23 PM
