Hi , Does anyone have any info on the VDO Factory Sat Nav unit that was available for the VY , It went in under the Radio/CD Stacker in the centre console, with a special tailor made Fascia panel. It had a Remote Control mounted on the Centre Console & the Computer & CD Rom mounted in the boot. Really need mounting details & User Manual if possible , maybe can get from VDO website but need a model number.... Any info or Pics would help a lot......
I have it in mine. There were 2 variants afaik. One had the cd mounted under the front pass seat and the other had the cd mounted in the boot under the left side of the parcel shelf which is what mine is. The kit comes with all mounting brackets which has the pre drilled holes in the frames from factory
VYII Calais L67
Thanks for that info- Can you tell me where the 12v power supply comes from for the boot unit & where the dash antenna bulb sits, also where the handheld remote holder goes on the console & how the head unit is mounted to the lower centre dash , pics would help , email to colgf2@optusnet.com.au , many thanks as I am trying to retrofit this kit to my VY as close as possible to factory fitment. Also where do you get the CD Rom map updates from???
