Results 1 to 4 of 4
Thread: VY SII cat converters moved forward?
    VY SS
    Aug 2004
    SE Victoria
    Angry VY SII cat converters moved forward?
    Hi All,
    Called hillside exhausts (experiences anyone?) and they said that extractors on a VY series 2 are a bit more costly dur to the cats being moved forward as compared to the VY series 2. As the cats are forward more i would need new cats and wiring loom extensions to accomodate a headers as the short headers do not do much.
    Also he quotes around $600 for a twin 2.5 inch mild steel cat back system with the center removed and replaced with hot dogs for a more raspy note.
    I would appreciate your thoughts.
    VY Exucutive S2 3.8 2004
    Aug 2008
    Bunbury
    Hi, iv got a S2 with pacemaker headers, i put them on myself, the sensors are in the same place (the wiring reachs). but the cats had to be moved. the headers are alot longer then the standard ones, and the cats ended up close to my feet. i re-used the standard ones, but they stuck out a little bit, and i used to bash em on stuff (and my car is stock height!) in the end i got some magneflow high-flo cats, and there much thinner and smaller. much better option.
    hope that helps.
    VE SS SPORTSWAGON
    Jan 2006
    Warwick
    the ss is different to an executive. i had to get the extensions for mine as well.
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    The stock cats are triangular shaped things that live next to the bellhousing, at about a 45 degree angle against the firewall. Most aftermarket cats will be flat units and they will be further back (aka cat-back) alongside the gearbox.
    The O2 sensors do get moved, and for a VY or MY05 VZ you will need 2 sensor loom extensions (about $60 from memory). Consider yourself lucky you don't have MY06 VZ, they have 4 sensors
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
  1. Drivers side front wheel moved forward
    By VT97 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-06-2008, 11:07 AM
  2. Rolling Forward in Reverse
    By Lindsayr in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-10-2007, 09:34 AM
  3. winding odometer FORWARD
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-06-2006, 10:51 AM
  4. Ambrose forward thinking
    By markovr in forum Motorsport
    Last Post: 11-06-2005, 06:51 PM
