hey guys sorry to be a complete nuisance and sounding possessive but i need some help with my vy s rear badges. My car has been debadged for over a year now and i'm starting to dislike the look and want to put the commodore and S badge back on. I don't want it to look like a scrappy job so i need some measurements so i can position the badges in the same place as when they came out of the factory. I have attached a photo with the measurements i would like. For the commodore badge its basically the distance from the edge of the boot to the "C" and the distance from the bottom of the boot to the badge. As for the "S" badge its the distance from the bottom of the boot to the end of the S (straight line) and the distance from the bottom to the tip of S (also straight) then the distance from the tip of the S to the end of the boot.
Your help will be much appreciated...opinions welcome 2
Holden should be able to supply you with a printed out jig of sorts. Cut out the edges and the space for the badge, line it up with the edges of the panel and stick away
VYII Calais L67
from the far left to far right.
17mm, 42mm,
35mm, 60mm, 32mm
thanks heaps 0081
