I have owned the car since new & have never had any front end damage. I have always returned the car to the dealer that I purchased it from. The Dealer & Holden don't want anything to do with it. It's had 4 wheel alignments,2 in spec 2 out,another 3 not accounted for (lost paper work). The latest alignment was in spec both front & rear.Due to the tyres being on the rear for 8000kms before being rotateded to the front it dosen't count.Even though prevuosly they were quite happy to use tyres from the rear.This 10th set are new ,inspected fortnightly and alingment to be checked every 2000kms.
This car should of been painted yellow! Its had a clutch,pressure plate and flywheel replaced at 9000kms a hose and fuel gauge recall.A cluth slave cylinder replaced (gear box out again). A horn operating on its own accord due to a sticker curled up under the airbag.Then several fuel senders before the fuel tank warped.A new fuel tank another couple senders and finally a new fuel cap that fixed the whole problem!! And still only 42,000kms on the clock!! :b: :b: :b:
