Results 1 to 24 of 24
Thread: Another suspension thread...
    Cosmo VY Ute
    Sep 2007
    Default Another suspension thread...
    There's probably about 100 posts on this but I'm in the South-East suburbs, wanting to know of a good place to get my ute lowered, preferably around the Dandenong - Cranbourne area. Thanks.
    VY S L67
    Nov 2007
    rowville - tyres and more
    they deal in alot of race set ups and are no-bs.
    or you could do it yourself
    Cosmo VY Ute
    Sep 2007
    Thanks mate, but i found a place that's local, says he will do it for $550, just the springs fitted.
    To my understanding the S2 VY's are fitted with fe2 suspension, so will i need shortened shocks or can I get away with not having them...
    VY S L67
    Nov 2007
    Quote Originally Posted by adamprezz View Post
    thats a rip.
    $300 for brand new king springs, and $250 labour?
    i had koni yellows installed (pre purchased), new king springs installed, all for $650, and that includes the cut and shut on the front konis... that was at tyres and more
    daniel555's Avatar
    daniel555 is offline Custom VY Commodore
    VY Executive S2
    Apr 2009
    Vic, Australia
    Cosmo VY Ute
    Sep 2007
    Ok thanks, now what springs to go with, i've got a set of aftermarket 19" Sigs to bolt on, I'm wanting the ute to sit flat rather then having it lower at the back... Suggestions?
    daniel555's Avatar
    VY Executive S2
    Apr 2009
    Vic, Australia
    SSL's at rear, SL's at front. Commodores sit front down.
    Depends how low you want it aswell, You have a ute? So you using it for work? If so, Dont lower it. Maybe SL's.
    Cosmo VY Ute
    Sep 2007
    I don't use it for work as much anymore, so it doesn't matter how low...
    A few guys have said SSL in the front, and SSSL in the rear.
    I don't want to have to roll my guards either, so would these springs sit ok with the 19's?
    daniel555's Avatar
    VY Executive S2
    Apr 2009
    Vic, Australia
    With SSSL's at the rear (same as my car), You'll def need your gaurds rolled. SSL's rear and SL's you'll prob get away with not rolling them. Depends on the wheel offset and alot of things.
    If you want it real low, roll your gaurds yourself. its not hard, And you can spend a whole day on it, making it perfect. Just use a heatgun and something hard/round. like a 100mm metal pole or something.
    Cosmo VY Ute
    Sep 2007
    If i were to put Super Lows all round is it still going to noticebly sit higher in the back? And how much of the wheel would i be tucking?
    VE SS SPORTSWAGON
    Jan 2006
    Warwick
    superlows will sit the same as it is now only roughly an inch lower
    daniel555's Avatar
    VY Executive S2
    Apr 2009
    Vic, Australia
    Quote Originally Posted by VTPREDATOR View Post
    Yep, You will not notice a difference at all really.
    Go SSL's and SL's. Should be fine with that.
    dynoryder is offline Banned
    vp executive wagon
    Oct 2009
    A.C.T.
    with lowering commeys the thin you have to remember is the bearings on the strut tops can be dameged easily i would take it to a pro
    Cosmo VY Ute
    Sep 2007
    Bidding for a set of SL's & SSL's on eBay. It's up too $202 so far, good deal or not???
  15. #15
    daniel555's Avatar
    VY Executive S2
    Apr 2009
    Vic, Australia
  16. #16
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Quote Originally Posted by dynoryder View Post
    So chuck in a new set of bearings...what's the big deal there?
    It will take you an afternoon to do the springs yourself at home.
    Struts out, spring compressors on, old springs out, new ones compressed, new ones in.
    If you dont buy shorter shocks and leave the FE2 ones in there you wont even need to compress the springs to put them back onto the strut.
    There isnt really much you can screw up. It's 3 bolts, a couple of lines and a compression of the spring.
  17. #17
    VY S pack S2, 5 spd
    Oct 2009
    Mount Gambier, South Australia
    I bought myself a 2004 VY S2 S pack in Feb this year, i want to get it lowered far enough to have the cops scratching their heads, but not illegal.
    How much would a complete set up cost. i will also be putting a set of 19" Dolce chromes in the arches so will this be a problem.
  18. #18
    VZ AWD One Tonner
    Jul 2006
    For a KYB (which are FAR better than Monroe) shock and King Springs combo for the VY, you're looking at $675:
    KYB / Kings Commodore Lowering Packages!
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
  19. #19
    VY S pack S2, 5 spd
    Oct 2009
    Cosmo VY Ute
    Sep 2007
    I've put SL's in the back, going to get the front done this weekend. Back sits alot lower then i was expecting from the SL's... I'm assuming this is because the front isn't dropped yet?
  21. #21
    Cosmo VY Ute
    Sep 2007
    Frandy's Avatar
    Frandy is offline _____________
    '99 KN Laser 1.6
    Sep 2005
    Diamond Creek Melbourne
    that looks really nice, not too low.
    they'll still got to settle a little too, nice work
  23. #23
    vp executive wagon
    Oct 2009
    A.C.T.
    Quote Originally Posted by gslrallysport View Post
    yea kyb is a good shock
  24. #24
    VY 5.7 S Ute
    Jul 2009
    I've gone down to bump stop height all around.
    I've got Monroe GT Shortened front struts and have yet to do the rear shocks.
    Have about 30-35mm travel all around now that I have shortened front struts and shorter bump stops
    Still got original shocks on.
    Of course the rear springs are not captive and need to be.
    So I'm trying to find a set of shocks that will keep the springs captive.
    I was looking at the Monroe GT lowered gas shock, but am unsure if it will be short enough to keep the springs captive.
    Does anyone know?
    Also does anyone have any ideas as to what would be a good heavy duty shock for this setup?
    Please include model number if possible
    Would be sitting on bump stops if they were original ones, but currently have shorter ones.
    ute doesn't get used to carry heavy loads.
    It also looks like I'm going to have to camber kit the rear.
    Does anyone know if I can get away with just the one kit, or do I need 2?
    Thanks.
  1. Official VY "Suspension + Wheels Setup" Thread!
    By nEb. in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-08-2010, 06:26 AM
  2. Suspension and brakes thread
    By BANKS in forum Site Feedback / Site Problems
    Last Post: 17-06-2008, 11:22 PM
  3. VZ Suspension Thread
    By SV6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-03-2008, 09:50 AM
  4. Another suspension thread ....
    By desruction in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-07-2006, 01:14 PM
