Hi peeps have got a vy ss ls1 with cylinder head casting number 241 but have been told that the ls2 heads with casting number 243 are better is this true an will they be just a straight bolt on
(ohh and i can get the ls2 heads for free so wanna no if there will be any gain in performace)
LS2 heads are definitely better then LS1 heads
if you can get them it would be a good upgrade
yes they will bolt straight on
but you will need
new head gaskets,head bolts and lifters
cheers GM
But can i still use my ls1 manifold for the moment
as i plan to turbo at a later date and would like to change manifold then
cool thnx for reply will i get any gain from fitting these heads and why do i need new lifters
Ride: 2002 WHII Caprice (Dead), 2004 HSV GTO with 408cu Stroker (Track), 2004 LX8 Adventra (Street)
THAT was the point i was making they are for free
Well the ls2 heads will raise your compression ratio and you say you're planning on going down the turbo route.. So in saying that, you might as well sell them and put that money towards your turbo kit.. Thats what I would do if I were you..
-Nick.
