Results 1 to 3 of 3
Thread: sunroof- doesnt seal properly?
    Jul 2006
    Default sunroof- doesnt seal properly?
    Hi guys.
    Just bought a VY Clubsport and it has a sunroof.
    Now the sunroof doesnt sit properly. You can use your finger to push it up a slight bit when its closed and see a little bit of the sky. When you drive, the air must get under it as you can hear air coming in unless you close the shade.
    Does this sound like a seal problem or? I am not too sure with these things so any help appreacited.
    Many thanks
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    I have a Calais with sunroof , without doubt its the most complex thing to operate on the entire car!!!!! Whoever designed the control console complete with 5 different buttons should hang their head in shame. The most coomon problem is they seem to have a mind of their own- several times mine has sunk down below roof level , the cure is to run the sunroof fully open then fully shut, that seems to reset the "memory" (if it has one!!!!) I do know its connected thru the Body Control Module so anything is possible with its positioning from time to time. Try that anyway,
    vy ss
    Aug 2009
    traralgon
    Make sure it is just not sealing as i got a vy ss that i thought was just an adjustment problem but found out later the the glass was not sealing/stuck to the frame resulting in the glass flying out of the car whilst i was doin 100kmh down the highway
  1. vr not starting properly
    By trickyvr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2007, 10:52 AM
  2. How to tune amp properly?
    By Noy in forum Car Audio
    Last Post: 26-12-2006, 11:57 PM
  3. My heater doesnt work properly......
    By VQXTC in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-09-2006, 07:58 AM
  4. Sunroof Seal
    By haloeight in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-05-2006, 01:23 PM
  5. car not starting properly
    By paco in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-06-2005, 11:49 PM
