hi, i compleated my 150,000km service today and went to reset the service reminder, following instructions left on one of the other threds, held in the 2 arrows turned ignition on then it comes up with service reminder 150,000 ? then i press set and nothing happens, the only button that works is mode, witch takes me back to the main screen, witch is my electronic speed, i had the electronic speed put on it a couple of months ago, coud this be causing the problem?? or am i doing something wrong??
btw the speedo is at 149, 899,
thanks guys
well maby if you go over 150,000 it might let you
but i thought some cars had to have the scan tool used
yeah i might just have to wait till 150,000 and see if it will let me then
Check your handbook's instructions to make sure you're doing it right, I've never encountered a problem, no matter how many K's.
Make sure you're holding SET down and not just pressing it.
cheers this thread also helped me out![]()
