I know this is probably a pissy issue, but i was wondering peoples opinions, pros & cons, etc of having the engine cover (turtle shell) on or off?
Do a search mate, been done to death.
I prefer without, they look sad with the shell on.
I have the twin LS1 covers, they look awesome, painted the same as the colour of the car.
Extractors, 100cpi ballistic cats, Sureflo 3.5" medium exhaust, DUS OTR, Oztrack Tune, Phreddy dash, stereo, black windows, Lovell springs, and a good alarm
Turtle shells also trap the heat in,twin covers are the go.
hey mate its your decision wheather you want it off or on reallyme i would take it off an leave it like that.. no point putn separate covers on coz they hold heat to???? looks alot neater just engine showing!!!!!
Just remember that an engine is better warm than cold. Without the covers the engine takes a slight bit longer to get to that warm stage. So if you do above 3000RPM within the first 5 minutes of driving probably keep them on. As long as you have coolant that will make sure it doesn't overheat.
They look poop i reckon. Get some twin covers, heaps better.
painted mine satin black. looks a lot better now.
Painted the letters and numbers on mine. And the hold down bolts.
Thats not the turtle shell...
But looks ok anyways.
Piss that turtle shell off mate
GMH dont put stuff on their vehicles for no reason , Leave well alone...... I reckon....
97 WRX AWD
Tein Coilovers + EDFC Dampener Control - Whiteline heavy duty Rear sway bar - Whiteline Droplinks front and rear
Turbosmart dual stage boost controller
IHI VF34 Turbo - XForce 3inch TBE - Oversized TMIC - Unichip PiggyBack ECU
PPG Straight cut 1st & 2nd, Slight helical 3rd & 4th and standard fifth - HD Clutch - custom braided clutch line
02 wrx 4pot front calipers - DBA500 two peice slotted rotors - Steel braided Lines
BP98 safe tune @ 171.8awkw
