Results 1 to 3 of 3
Thread: check engine
    2004 lumina Ss vy a4
    Oct 2008
    Default check engine
    hi all,,,
    how u doing?
    hope to find an answer for my issue
    i have an message coming through my center display
    (( check engine ))
    that message shows only after the engine warm up
    and also if i drive the car below 90 km/h
    i checked the throttle and i cleaned it, i checked all the wiring,even i changed the engine oil
    when that message shows in the display the car RPM it will shudder between 400 to 650 RPM.
    seems that the engine wanna turn off but it doesn't turned off....
    notice: above 90km/h that message will not appear.
    hope u guys to help me to solve my issue.
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    Check engine is a very general error. Could mean many things, sometimes it even shows up when there is no need to.
    As to what i would check, check your vac lines. If one of those falls off it creates shudders and your engine wanting to stall. Vac lines has been the most common cause of symptoms like this.
    If not a vac line give a yell back, but i'd be putting my money on that,
    VY SS UTE
    Sep 2007
    Seaford VIC
    prob oxcy sensoir, mine did it
  1. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  2. VX SS check engine light
    By SSbeast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-06-2010, 05:56 PM
  3. Engine check up....
    By CHARGEDVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-03-2009, 08:29 PM
  4. check engine
    By zone B in forum VY Holden Commodore (2002 - 2004)
    Last Post: 09-06-2008, 12:56 PM
  5. check engine light comes on????
    By Brucefromruse in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-11-2007, 04:53 PM
