take the screws out of the liner and flex the middle up so that it pops out on the left hand side. There's a removable panel on the left side of your tray near the light. unscrew that to find your globes.
Hey,
I seem to have a problem. my issue is that I have a blown left brake light on my ute and I haven't had to change one yet so I dont know how to get into the light globes. It looks like you maybe able to access it from the back, but I have a tub liner which is bolted down and an LPG tank ontop of that!
Any Ideas??
Thanks Heaps!
Oh ok, Thanks, i'll give it a go tonight!
The panel you need has ~8 phillips screws in it. Once you get into that you will be able to twist out the globes you need. I dont have a tub liner so hopefully one and only's info will be enough.
Make sure you test both the parkers and brakes after you put the new ones in.
Hey guys, sorry about the VERY late reply on this thread, as you fellas said, I unbolted the tub and managed to pull and twist it out a bit, was very tight getting my hands underneath to unscrew the backs but now I know how to do it!
Thanks guys,
Mark.
