Results 1 to 6 of 6
Thread: how to remove grill on vy
    vys ute
    Aug 2009
    Default how to remove grill on vy
    anyone know how to get the lower grill out on a vy executive bumper without taking the bumper off.
    VY Commodore
    Oct 2009
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Quote Originally Posted by vy_03 View Post
    which lower grill? isnt there only one?
    VY S Ute has the executive bar which has a black plastic lower grille
    http://www.caradvice.com.au/wp-conte...ncommodore.jpg
    vys ute
    Aug 2009
    Quote Originally Posted by TMM View Post
    that's the one
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Skynyrd
    I don't know if this helps much, but you have to remove the bar to take out the lower grille on the Berlina and Calais, because they clip in from the back. There isn't a lot of space between the back of the grille and the chassis so leaving the bar in and just unclipping the grille and removing it needs the bumper to be removed (that is, for the Berlina and Calais).
    I suspect the same would apply to the Exec set up.
    Why not just remove the bar anyway? It's only a matter of a few screws and unclips from either side. Takes less than five minutes, but it helps to have a friend to support the end because it will flop around a bit when you unclip it.
    To remove it, you have three screws along the top above the grille, one on each side in the front lip of the wheel arch (you will see two screws, but you only need to remove the lower one),one each side under the bottom corner of the bar and two mongrel "scrivets" behind the number plate. Just don't try to do it single handed.
    vys ute
    Aug 2009
    calaber
    thanks for the info
  1. "How To" Remove Door Card & Speaker Grill on VT-VX *Detailed*
    By Ozzie in forum Holden Commodore How-To's
    Last Post: 05-12-2011, 05:25 PM
  2. [QLD] swap vy ss grill for vy berlina grill
    By paynetrainvy in forum Swap / Wanted to Buy / Trade
    Last Post: 19-08-2009, 01:03 PM
  3. hsv grill
    By reidy1990 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2009, 11:44 AM
  4. ss grill exec grill
    By SAV_117 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 13-12-2008, 02:03 AM
  5. Which Grill Looks Best
    By sixshooter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-08-2006, 12:08 AM
