Results 1 to 5 of 5
Thread: Clutch Creaking
    VY Storm
    Nov 2007
    Default Clutch Creaking
    Hey guys
    My clutch has started to creak whenever I push it in! It sounds quite bad.
    It started as quiet squeak. It doesn’t affect the clutch’s performance but does make the pedal feel a little rough.
    The sound is coming from inside the bell house.
    Any ideas what it might be?
    maginoodle's Avatar
    maginoodle is offline Donating Member
    vy series2 ss crewman
    Apr 2006
    thrust bearing is the likely cause, though it can be the spigot bearing/bush but it is probably the thrust.
    heres my ride, i know its not much but its mine
    http://forums.justcommodores.com.au/...-ss-crewy.html
    and heres my new project
    http://forums.justcommodores.com.au/...ml#post1104629
    VY Storm
    Nov 2007
    Thanks maginoodle.
    I'm guessing that will require the gearbox to be unbolted?
    Is that an expensive job to replace a thrust bearing?
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    thrust races arnt that expensive, just time consuming
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    VY Storm
    Nov 2007
    Yeh i figure the cost will be mostly labour...
    Will take it to holden and get a quote.
    Thanks for the help.
  1. Brakes creaking when hot
    By aceventura in forum General
    Last Post: 15-02-2009, 12:33 PM
  2. window squeaking and creaking
    By rick79 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-12-2008, 12:34 PM
  3. creaking noise when turning
    By freddys in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-01-2007, 11:53 AM
  4. Creaking Front End
    By VT TOMMY in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-09-2005, 09:55 PM
  5. Creaking/squeaking GTR
    By rubygirl in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-08-2005, 12:48 AM
