Hi, First time posting so go easy haha. Could some tell me how or link me to how to remove the piece of plastic at the bottom of of the windscreen where it meets the bonnet. I can see 6 screws of where to undo it but they do not seem to undo.
Cheers,
Ben
Those screws are actually called "scrivetts" which can be very annoying to remove. You need to hold the outer part of the scrivett while unscrewing the centre part (trying not to put too much pressure on the screwdriver or the centre will just push back in). If this dosen't get them out, you can use a small hook/pick to dig out the centre. When putting them back in, put the outer part in first then push the center part in with your finger. Once you get one out, you'll see how they work.
After you have removed the scrivetts, there is 5 or 6 clips still holding the plastic on. Just work from one side of the car to the other gently popping up the plastic (be careful not to scratch the plastic on the corner of the bonnet).
Hope this helps mate.
Thanks heaps mate, yer ill give it a try. Cheers, Ben
Ah that's how u do it...
