Hi Guys,
I have a VY Monaro and my climate control fan is not working at all checked fuses and relays and still no good.
Can anybody help me as its coming to summer and dont wanna fry......lol
Dont know if your talking about the fan or the climate control not working at all. My fans was working just did not have climate control as the aircon pressure switch wire had come off after doing some work in the left front headlight. so maybe just have a look at that and see if it helps.
Biggls
Does you fan work on "Max" but no other speed? If so, it will be the amplifier. Check search function for a previous post on this matter for VY's a few months back.
It's located above the glovebox and is easily removed. It can be repaired by re-soldering the connection or replaced for around $80.
Thanks for the reply i will check both of these out.
Cheers biggls
