Results 1 to 5 of 5
Thread: replacing brake pads doing my head in...
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Default replacing brake pads doing my head in...
    i bought myself a 322mm front brake kit for the ute. I'm trying to get the pads in before i put them on tomorrow and can't work out how the hell to get one of the pads to sit in the little clip - every time i try to use a bit of force the whole thing shoots out and scratches the caliper...
    Any ideas?
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    once you have the grey bits bolted to the car it will be easy as
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by delcowizzid View Post
    Quoted for truth.
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Yep. Bolt the caliper bracket in place, position the clips and pads, then lower the caliper over the pads. If you try to assemble it your way, you'll go mad.
    Mar 2008
    You guys were right. I put them on this afternoon and everything just slipped in. Only problem is parts of the metal spring holder bits are rubbing on the rotors and it's squealing - a job for tomorrow i think.
  1. Replacing front brake pads
    By Jamkat in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-07-2008, 03:44 PM
  2. replacing brake pads hat do i need
    By Boris-vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-02-2008, 08:42 PM
  3. How to tell if brake pads need replacing?
    By ozzie_online88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-10-2007, 08:11 PM
  4. Replacing VT front brake discs and pads
    By flukey77 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-11-2006, 10:25 PM
  5. VT Commodore - Replacing Brake Pads
    By U2Bono in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-10-2005, 02:54 PM
