Results 1 to 13 of 13
Thread: Handbrake not holding
    '04 vy s series 2
    Feb 2009
    Default Handbrake not holding
    g'day guys, my handbrake is not holding. there is tension when you apply it but the ratchet / clicking sound is not there and consequently won't hold. Anyone know how to fix it ?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Sounds like the spring that holds the ratchet in place has either broken or dropped out. You will need to pull the console apart to get to it.
    Visit my Facebook page
    '04 vy s series 2
    Feb 2009
    Quote Originally Posted by Not_An_Abba_Fan View Post
    you're kidding !! is that a difficult job ? can't i get to the handbrake off without doing that ? i can see a couple of nuts to undo after i've taken the boot cover off. looks awkward but i reckon i could reach them without taking the consol apart.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    If you think you can get to it, give it a go. The console isn't that difficult to remove though. Do a search, I'm pretty sure it has been covered.
    VZ Calais
    May 2009
    im having the exact same problem, pretty dangerous. lucky mines covered by a warranty
    daniel555's Avatar
    daniel555 is offline Custom VY Commodore
    VY Executive S2
    Apr 2009
    Vic, Australia
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Quote Originally Posted by skookumchuck View Post
    How to: Remove Dash and Center Console VY-VZ
    I had to do this to my SV6 to adjust it. When u adjust the nuts on inside of the wheel you'll have to do the same inside the car, hence y u have to remove the centre console.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    '04 vy s series 2
    Feb 2009
    Quote Originally Posted by daniel555 View Post
    Handbreak
    $42 for a new handbreak, Easy to install.
    i'll give it a go this wekend i hope and i'll report how 'easy' it was !
    VY executive
    Oct 2008
    I had the exact same problem about a month ago and made the exact same thread lol.
    Just replace your hand break leaver, not to expensive.
    Listen to Daniel555, he knows what hes talking about.
    '04 vy s series 2
    Feb 2009
    Quote Originally Posted by VjamesY View Post
    yeah i think i'll do that. didn't get time this weekend anyway. how did you go about getting it off ? remove the consol or the two bolts on the handbrake ?
    '04 vy s series 2
    Feb 2009
    Default vy handbrake removal
    what a load of crap about taking the consol out !!
    slide the seat back, lift the handbrake boot up and undo the two 15mm nuts. then with a long nose pliers take the electrical clip off the sensor and then undo the cable nut with a 10mm rachet spanner. off comes the handbrake !
    now i need to take off the boot cover. i can see the arm that holds the yellow lever is loose so i reckon the spring is broken or come off. i'd like to take a closer look to see if it can be fixed or buy a new one.
    anyone know how to take the cover boot off without wrecking it ?
    '04 vy s series 2
    Feb 2009
    Default vy handbrake fixed - no cost !
    got the boot off by searching other threads. by getting a small screwdriver i flipped the back of the plastic handle up and it just flipped off. sliding the boot cover off i noticed the metal part that attaches to the long yellow plastic bit that the thumb button on the handle operates had broken. rather than buy a new handbrake i explored ways to fix it. i came up with drilling a small hole in the plastic lug and wiring it to the metal arm. bingo ! works a treat. putting it all back was a bit fiddley but handbrake is now working fine. i'll post a couple of pics. later so you can see what i mean.
    '04 vy s series 2
    Feb 2009
    Default handbrake problem pics - fixed
    here are the pics of the handbrake fix. nah, didn't work !
  1. vx ss holding 1st gear too long
    By cubic inches in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-06-2009, 10:12 PM
  2. Battery not holding charge (Please help asap)
    By scatterybrane_007 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2009, 07:49 PM
  3. Holding Revs
    By vt s in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-03-2009, 03:02 PM
  4. VL Automatic holding 1st when cold
    By rx3 madman in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-04-2006, 09:18 AM
  5. trans holding gear
    By flip1906 in forum V6 Development And Modification
    Last Post: 21-12-2005, 06:17 PM
