Results 1 to 3 of 3
Thread: Alloytec to vn
    VN MODIFIED SPEEDWAY ALLOYTEC
    Nov 2009
    Default Alloytec to vn
    Hi i have put an alloytec 175 kw into my vn i have put the alloytec ecu and auto control in as well having trouble with the loom getting the ecu to come to life. any suggestions.
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    get this moved to the VZ section - they're the ones that had the alloytec motor, and you'll probably find a bit more help there.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    VE SSV
    Jul 2006
    you wiring in the BCM... you will need to as its the only way to remove the security.
    We play with all the good toys - LS1 LS2 L76 L98 LS3
  1. alloytec 190 into a vb
    By white vn ss in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-11-2009, 09:10 PM
  2. 5W-30 oil for alloytec?
    By listen_to_slayer in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-11-2008, 07:10 AM
  3. 3.6 alloytec
    By Stretchomatic in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-06-2008, 07:22 PM
  4. Alloytec anyone?
    By one_and_only2004 in forum V6 Development And Modification
    Last Post: 18-05-2008, 08:27 PM
  5. Alloytec and Alloytec 190 Engine Specs and Details
    By Gobbles in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-06-2005, 05:24 PM
