Results 1 to 10 of 10
Thread: VY Aircon
    VY '03 SS
    Apr 2008
    Default VY Aircon
    Hey
    I got a question bout my aircon. Obviosuly it was extreme temperature the other day, but it seemed my aircon couldn't keep up. I've got a VY SS . I had the aircon running on #4 and blasting on my face but it still seemed weak. It just wasn't that cold
    How cold does it normally drop the temperature down to in the cabin ?
    It seemed to work ok when the temperature droped, typical.
    If i was to get the aircon serviced, do you think it will improve the temperature ? And i've recently had the aircon belt changed aswell..
    VY Berina 5.7Ltr
    Oct 2008
    yeah. it may be low on gas mate, i recommened re gassing it.. because if it runs out of gas it will cause problems with the compressor.
    What about at idle? is the aircon fine then or?
    VesperZ's Avatar
    VesperZ is offline 2005 Holden VZ Berlina
    VZ Berlina
    Jul 2009
    Sydney, NSW
    I had this exact problem over the weekend, it was literally 40+ degrees yesterday and my aircon couldn't keep up either. Not sure if mine needs to be regassed as well. As soon as the temperature dropped a bit it was fine again. Let me know if you end up getting yours regassed and if it solves your problem.
    VY '03 SS
    Apr 2008
    i rang up Natrad, nd they told me that even on a good day, the car would struggle to keep up. they offerd me to drop it and have a mechanic hav a look @ it for free , but they quoted $150 to regas
    i might ring up another local firm nd get there opinion
    -scyth-'s Avatar
    -scyth- is offline Im alright its the others
    VZ Wagon 05
    Nov 2008
    Yeah trust me the natrad guy is correct. a lot of a/c units struggle on 40+ days. I'm an ex fridgy & i came across a lot of these type of jobs on a regular basis during the summer months. u'll see the a/c will work better on the freeway on a 40+ day instead of local traffic conditions. Also, if the temp is too high there's a safety relay that stops the compressor from over heating & loosing all its oil or worse still burning out; so you can imagine on a 40+ day & the temp in the engine bay combined will stress out any a/c unit.
    VYII Acclaim
    Jun 2008
    Largs Bay, Adelaide, S.A
    I ran my A/C no higher than 2 on the fan speed and set it to recirculate. I had no problems cooling on 40+ days.
    binghy is offline Matty 038
    Vy Equipe Series 2
    May 2009
    adelaide
    In Adeliade the other day it was 43 and i had my fan on 1 and it was cold get your air regassed and this will fix the problem
    VY s m5 supercharged
    Aug 2008
    If it needs to be regassed it has leaked out and there will be a leak somewhere that will need to be found and fixed.
    Also 150 just to regas is a bit high i think, but i do work in the a/c and refigeration game and i can get the gas cheap.
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Quote Originally Posted by 0081 View Post
    Agreed.
    My A/C has never been regassed and it's still cold like a freezer.
    VY Storm Ute
    May 2009
    Quote Originally Posted by scozz76 View Post
    The truth has been spoken.
    Never put your aircon above 2 (unless you are purging hot air out). You need to give the air time to be cooled.
    If it's hot as hell outside, stop taking air from outside. Simple.
  1. wiring a neon to the aircon switch to show that the aircon is on
    By 12000 in forum Electrical Wiring / Questions
    Last Post: 25-03-2007, 08:44 AM
  2. vp aircon
    By pr0n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-02-2007, 09:23 PM
  3. VH aircon
    By 4PLAYN in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-11-2005, 07:36 PM
  4. VN Aircon
    By paddyj in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 08:30 PM
  5. aircon fan
    By dibly1980 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-02-2005, 11:02 PM
